Making A Joist A T - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 12:39 PM   #1
Rewards Points: 1,092
Making a joist a T
Situation: A person needs stronger floor joists and can't add much height. Sistering the same size joist will double the load, but is a lot of wood. Question for an engineer: What can be gained by adding strips of plywood, say 3" wide by 1/2" thick and overlapping joints, to the bottom of the joist, making a T? Since the top of the joist and floor are already a T, really, wouldn't this make an I beam out of the joist, and hence increase it's load carrying capacity? If so, by how much? Dan: crunch some numbers on this one, pls!
Old 10-04-2010, 10:34 PM   #2
jlhaslip's Avatar
Rewards Points: 2,186
a waste of time and material.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-04-2010, 11:26 PM   #3
It will add virtually nothing extra to the load limit or rigidity.
hayewe farm is offline   Reply With Quote
Old 10-05-2010, 01:34 AM   #4
And why would it not help? When a joist sags, the bottom is in tension and the top is in compression. It seems that plywood down there would have to reach its tensile strength to fail. The joist would then be the I beam's web, the floor and the new plywood being the flanges. Same principal as a steel I beam or a TJI/BCI, no? Maybe I'm missing something here. Wait. I AM missing a few things; screws, but that has been that way for decades.
Old 10-05-2010, 07:58 AM   #5
Civil Engineer
Rewards Points: 4,782
You can stiffen a joist this way, however the key issue is horizontal shear that develops between the old joist and the new plywood. This has to be addressed correctly via the use of an adequate number of fasteners, possibly glue, between the plywood and the joist. I have never actually seen this done in practice on a wooden structure. You see it all the time on bridges, where the beam has a welded on steel plate on either the top flange, the bottom flange, or both, which deepens the section and adds to the moment of inertia. On old railroad bridges you can find cover plates that are riveted onto the original steel channel.
Old 10-05-2010, 10:53 AM   #6
Originally Posted by Daniel Holzman View Post
You can stiffen a joist this way...
Dan: Thanks. I suspected this would work. It would certainly be a lot more time than money, but sometimes we have our resources distributed that way. When I get time (ha ha) I am thinking of mocking up a floor w/ 1x4s on a sheet of 1/2" plywood and put a load on it, then add bottom strips, just for kicks and giggles. It may not be enough stiffening to dink w/; shall see.
Old 10-05-2010, 12:05 PM   #7
Chicago, IL
Michael Thomas's Avatar
jklinger,
Plywood won't help, however steel strapping might, see pp: 94 here:
http://www.google.com/url?sa=t&sourc...WiqeIw&cad=rja
- or -
http://tinyurl.com/2by5dhx
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-05-2010, 02:22 PM   #8
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
Plywood is one of the last wood-based materials on the planet that I would specify for this. The ply's are oriented 90 degrees off every other ply, so half the material is oriented in the weakest plane. These perpendicular plys contribute very little to tensile strength. My money is on the plys running perpendicular to the joist failing the first time you load it (which will put even more stress on the plys running the right way, which in turn will lead to those plys rupturing).
Aggie67 is offline   Reply With Quote
Old 10-05-2010, 03:40 PM   #9
Mike: good link. thanks.
Aggie: Good point on the plywood. The reason I thought of ply is because that is what (maybe) TJIs/BCIs are made of. That said, are the flanges on BCIs/TJIs all parallel laminations, or do they rely some on the glue? Maybe OSB would work better than plywood... till it gets wet. Looking at Mike's link, those steel straps are probably the easiest way to get at least some help, esp if you criss-crossed them and had two in there. OK; I'll work on another idea.... later. j
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
