Making Holes In Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 10:03 PM   #1
Making Holes in Concrete
I am about to put a wood deck over my backyard patio. It isn't feasible to remove the old concrete. What kind of tool and method should I use to put holes in the concrete to mount to supports for the wooden deck?
LeHeretic is offline   Reply With Quote
Old 06-28-2011, 05:53 AM   #2
Rewards Points: 5,336
Generally a patio slab isn't adequate support for a deck. You would need to open the slab and pour footings below the frost line. If your area requires permits, the inspector will want to see holes dug that deep before you pour the footings.
Post your location.
Ron
B. Franklin 1759
Old 06-28-2011, 09:42 AM   #3
Post your location.
I live in Kitsap County, WA. Thanks for the support.
Old 06-28-2011, 06:02 PM   #4
Rewards Points: 4,790
did this on our 2nd home in upstate ny where frostline was typically 3'6",,, the deck was only 8" high over the existing conc patio,,, could have removed the conc but didn't feel like it,,, gravity kept the new wood deck in place, the frost didn't heave it, the bldg inspector had no complaints since it wasn't attached to the house NOR on conc supports,,, assessors didn't raise the property's assessed valuation, either, therefore no increase in taxes
Old 06-29-2011, 08:59 PM   #5
Change of heart
Now I am thinking about doing a floating foundation deck system from deckplans.com. What do you think about that idea? It seems pretty easy and quite a bit cheaper.
Tags
concrete , drill , hole , holes
'hard patching' blast holes in concrete warehouse floor shag_carpet Flooring 0 09-08-2010 04:29 PM
Small holes forming in newly poured concrete chitownIrish Building & Construction 4 07-10-2010 02:24 PM
Concrete post holes cambishop Building & Construction 4 05-26-2010 08:12 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
