Old 04-09-2009, 04:25 PM   #16
Wildie, this is exactly my problem but I do not understand how you did it.
Arvind is offline   Reply With Quote
Old 04-09-2009, 06:06 PM   #17
I dug down to the 4' level using a shovel and clam style post hole digger!
Under-mining the existing foundation in such a manner that the pocket for the 16" square footing was centered under the foundation.
I then filled this pocket was cement to a depth of 6" and let it setup!
Then I cut a Sono tube down the middle,lengthwise leaving enough of the tube to slip under the corner of the foundation.
Then I back-filled the hole to keep the tube in place.
Then made a sloppy mix and filled the tube up, tamping all the while, making sure that it flowed under the the old foundation.
I pushed some 3/8" re-bar down into the mix to reinforce the pier.
More On This Topic
Hi I'm Karen for Expert Village. Now we will prepare our pocket section. Take the two front two pocket sections and place them right side together and we are going to sew all the way around and leave a three inch gap. So we can turn the two pieces. Now... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I am going to show you another method for making pocket cuts. Another method for making pocket cuts which is quite a bit easier is to take a drill and drill a hole on the inside of our box... Read More »
Now I'll start by putting our pockets together. You want to make sure that when you cut your pockets out of the old jeans that you leave enough fabric around it to work with. So I have about 3/4" all the way around my pockets. Now you'll want to place... Read More »
Whitewater Raft Designs
Whitewater Raft Designs by Expert Village
Hi, we’re going to talk a little bit about whitewater raft designs. Right here I have a self-bailing raft which is the most common raft out there used commercially now, starting to be a pretty common boat to be used privately as well. This is a... Read More »
If you're traveling, you'll want to be careful with important items, such as your travelers checks, cash and passport. The best way to make sure none of these things are stolen is to sew a hidden pocket or two into your jacket. Unless your entire jacket... Read More »
Pouring Footing for PWF walkout basement billybarty Building & Construction 0 06-19-2008 01:24 PM
footing drain question chrisk Building & Construction 2 09-02-2007 09:21 PM
How level does a footing need to be? tripower Building & Construction 1 05-03-2007 10:59 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 04:22 PM
New addition old footing problem meashmut Building & Construction 2 04-20-2006 08:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
