Old 03-03-2009, 06:12 PM   #1
Novice
Send a message via Yahoo to stewbstew
Post Making a footing for slab that already exist?
After going to the county to get a building permit, I find out that I will need to make footing for a slab that already exist. Does anyone have any suggestions?
Thanks!
stewbstew
stewbstew is offline   Reply With Quote
Old 03-03-2009, 06:36 PM   #2
The footing needs to be at the frost line. Did the building dept tell you what this is? Can you make the footing and new foundation wall along side this slab? then use a expansion joint between the slab and the foundation wall.
Bob Mariani is online now   Reply With Quote
Old 03-03-2009, 06:43 PM   #3
Thanks!
stewbstew
What kind of slab are we talking about? A patio? A house? Is the footing to support the slab or some structure on the slab?
Old 03-03-2009, 08:11 PM   #4
I had to do this recently! The frost line in my area is greater than 3 feet. I had to dig down to the 4 foot level and pour a pad, 16" square.
Then I notched out a Sono tube, so that half of it fitted under the under-side of the slab!
I then back-filled the tube to keep it in place!
Then I filled the tube with cement!
It would depend on what you plan to erect, on how many of these piers would be required.
Old 03-03-2009, 09:20 PM   #5
Novice
Post
Yeah, its a patio type of slab that was turned into a laundryroom, however, I don't think they got a permit to do so because it was a mess. Actually, I was trying to remodle it to breing it up to code.
Anyway, so I live in Arizona, and I not sure if the frost line is a factor. Therefore, do you think digging down the side of the slab and in about a foot then pour concrete into area I dugout?
Anyway, thanks so much for replying!!!
Old 03-03-2009, 09:25 PM   #6
Novice
Post
Thanks for replying!
So...do you think digging down the side of the slab about 3 or 4 foot and in about a foot then pour concrete into area I dugout will work? Thanks again!
Old 03-03-2009, 09:42 PM   #7
Extreme DIY Homeowner
Scuba_Dave's Avatar
I doubt the Frost line is 3-4' in AZ
Scuba_Dave is online now   Reply With Quote
Old 03-03-2009, 10:38 PM   #8
I'm in Canada, so the temps stay below freezing, months on end!
I'm unsure what your frost level would be, but I doubt that it would even be 12".
In my case, the building inspection people advised me on how deep to dig! Can you not find out from your inspection dept. what is required!
In your case, I would dig a trench around the perimeter. Perhaps 12" deeper than the bottom of the pad, then undermine it for about 8". Then fill the trench with concrete with rebar running parallel and under-neath the slab a few inches!
Old 03-04-2009, 04:20 AM   #9
Novice
Post
Okay my friend, we'll look at that. Thanks
Old 03-04-2009, 04:23 AM   #10
Novice
Post
Hi,
no they did not tell me what it was, he just told me to come back with plans on the foundation and I guess he'll tell me yes or no then. Go figure. Anyway, thanks for the suggestion.
Old 03-04-2009, 04:25 AM   #11
Novice
Post
Yeah...probably so.
Old 03-04-2009, 07:02 AM   #12
call your inspector and ask.. You need to show this depth and details of rebar and such on your plans.
Old 03-04-2009, 09:21 AM   #13
BUILDER / REMODELING CONT
buletbob's Avatar
Yes call your building dept. and find out what your footing depth should be. And wildie has the right approach, that's called underpinning. BOB. Is the slab at least 6"- 8" above grade. Be cause if its wood framed this might be a problem with the sill plates not meeting the code height. BOB.
Old 03-04-2009, 09:38 AM   #14
Default Craneservice
You may have to pour the footer and stem wall in sections in order to keep the slab supported. You must leave at least an inch of space between the stem wall and the slab. Fill the gap with non-shrink grout if you pour to the bottom of the slab with concrete when the concrete sets it will pull away from the slab and leave a small gap. The slab will then be unsupported until it settles or cracks to sit on the stem wall.
craneservice is offline   Reply With Quote
Old 03-04-2009, 10:54 AM   #15
Novice
Post
Thanks guys, that really good advice.
More On This Topic
Alright, now we’re going to talk a little bit about the preparation for your foundation. The best thing is to not have your rebar sticking up too far past what your first bale will protrude through. Maybe just a little bit to helping lock in that... Read More »
Hi! I'm Doug Smiddy of Smiddy's Gardening Services here on behalf of expertvilalge.com. Today we are going to talk about how to plant, grow and harvest potatoes at this point. Now bearing in mind that potatoes are an underground crop, I want to prepare a... Read More »
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
A wire gate is a great and simple way to keep wild animals, the neighbor's pet and children out of your garden or yard. It can also keep small animals in place and out of harm's way. Take your time to examine and reinforce a wire gate. Read More »
Here’s some of the things that we’re going to be using today. Some of these things won’t be used only because instead of the blocks I’m going to demonstrate the straw bales being mounted to, you’re typically going to have an... Read More »
Pouring Footing for PWF walkout basement billybarty Building & Construction 0 06-19-2008 01:24 PM
footing drain question chrisk Building & Construction 2 09-02-2007 09:21 PM
How level does a footing need to be? tripower Building & Construction 1 05-03-2007 10:59 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 04:22 PM
New addition old footing problem meashmut Building & Construction 2 04-20-2006 08:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
