Making Fence Post Holes In Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 07:05 PM   #1
Rewards Points: 101
I'm going to install a vinyl fence and most of the posts will be placed where there is existing concrete. I was wondering what is the best method for making the holes in the concrete? My Dewalt drill has a hammer drill setting. Should I just get the largest masonry bit and make multiple holes until I can chisel it into one large opening?
jte1130 is offline   Reply With Quote
Old 09-21-2009, 02:13 PM   #2
First off, pls. consult a contractor. Even if for questions, A real, true contractor will always give honest advice. Hopefully you thought of rebar, reinforcing steel, if you run into this, and it's in the way of the post placement, then what? How What are the posts made of and what method were you thinking of to anchor them?
"Not a Contractor, just well schooled"
d.sharkey is offline   Reply With Quote
Old 09-21-2009, 07:07 PM   #3
Rewards Points: 4,796
diamond core drill on a stand which's bolted down to the conc,,, you can hurt yourself if its not done right, too ! IF you have a 1 3/4" drill, you could use that but finding the adapter's impossible unless you buy it,,, your drill's not set up for waterfeed so don't forget the gfci.
yes, your method'd work - just look like hell !
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Help repairing fence post CAP 5 1/2 x 5 1/2 DeanBohl General DIY Discussions 1 10-23-2008 05:45 PM
Concrete piers for post & beam foundation jpecor Building & Construction 1 08-01-2008 12:27 PM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 01:09 PM
