Making Cold Room In Basment For Storage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 09:13 PM   #1
Rewards Points: 159
Making cold room in basment for storage
I have a corner in my basement that I want to make into a "cold room"
The basement is currently poured walls with a cement floor.
I am going to wall off/insulate from the rest of the basement, including the ceiling.
I am assuming that I do not want to insulate the outside walls/floor. As this is how it will keep cold.
But I do want to make sure I do not have mold issues. Thoughts on the floor? I was thinking stone tile.
Cement walls could be painted with epoxy?
Inside walls that I make could be lined with wood that is stained/polyurethane?
I am wondering if I am going to have high humidity issues with this?
theedudenator is offline   Reply With Quote
Old 08-03-2011, 08:29 AM   #2
Newly Retired
tuchodi's Avatar
I have a cold room and it has a dirt or sandy floor. All the cold rooms I have seen that work really good do not have a solid concrete or tile floor so I am not sure if you will be able to achieve the proper results as humidity is very important and the dirt floors seam to control that. I know that commercial cold rooms have concrete floor but they have a very elaborate cooling and humidity system.
tuchodi is offline   Reply With Quote
Old 08-03-2011, 08:44 AM   #3
Rewards Points: 5,336
What is the use of the cold room? That information will help.
If you live ia a humid place, the room will be humid. Where I live, the dehumidifier runs from May through October.
Ron
B. Franklin 1759
Old 08-03-2011, 07:59 PM   #4
Rewards Points: 159
It will be a wine cellar
Optimum is 55 degrees F year round.
with 55-80% humidity.
So it really isn't that dry to begin with.
I would probably have more of an issue with the summer temp!
Old 08-03-2011, 08:18 PM   #5
You will need a cooling unit in the room to maintain the 55 degrees in the warm months. My "cold room"(crawlspace) is now 72 degrees F. During the late Fall, Winter and Spring it ranges from a low of about 50 to 60F.
It will also need to be well insulated or the unit will run constantly.
Ron
B. Franklin 1759
Making room up in attic Proby Building & Construction 7 07-31-2010 08:24 PM
Cold room above garage, Asbestos? Crackers Building & Construction 1 09-09-2007 09:35 AM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 05:06 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 11:51 AM
Adding a vent in cold room... AllGoNoShow HVAC 1 11-21-2006 11:16 AM
