Prev Previous Post   Next Post Next
Old 04-02-2009, 03:44 PM   #1
Default Making back stairs
I need to make some back steps for my house. The stairs are for a door that would only be used during a fire or emergency so they don't need to be too fancy. They need to be about two and a half feet wide by two and a half feet tall. Now I'm not sure if I should go with wood or some sort of large stone/brick. I've seen some large gray stone... brick looking things for garden landscaping at Menard's and wonder if I could use those with some mortar to make some easy, affordable steps.
Any tips would be appreciated
Sarah24 is offline   Reply With Quote
Tags
brick, stairs, steps, wood
More On This Topic
The dry-mortar method is an easy way to fill the space in masonry joints when you're building a patio. One of its advantages is that the mortar keeps those pesky weeds from sprouting. Whether you're using bricks or concrete slabs, consider filling the... Read More »
It’s important for every home owner to familiarize themselves with the exterior of their house. A lot of times people don’t check on what’s going on outside their house. Especially on the side that they rarely see - until there’s... Read More »
If after a rain you notice water collecting underneath your brick stairs, then you may have a brick stair leak. Afraid that you will have to spend thousands of dollars to have your stairs rebuilt? Slow down--this might not be the necessary solution. Read... Read More »
Making a masonry planter is a good way to add aesthetic value to your home. They work well in yards and can also be used to add foliage to areas that are covered in concrete, tile or other non-dirt surfaces. Read More »
Stone is very popular for landscaping and walls around the home. It is enjoyable and natural looking. A professional mason can put up a beautiful brick wall made of stone in no time, making the work look effortless. But his masonry tools are used... Read More »
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 11:20 PM
Vinyl flooring on stairs, need input mgarfield Flooring 6 01-30-2008 12:04 AM
Foundation Work - Installing a walk up stairs handy man88 Building & Construction 2 10-01-2007 02:19 PM
Railing on Stairs Melanie337 Carpentry 6 10-04-2006 11:39 AM
open stairs = header jamesdart Building & Construction 0 09-08-2006 04:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
