Making A 2x6x12 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 12:21 PM   #1
Making a 2x6x12
Hello All, First time poster =D
I am planning on building an arbor very shortly, and was wondering what the best/proper way to connect two 2x6x8's to make a 2x6x12.
Id like to have as less noticable hardware as possible
1) Take a large, deep, notch off the ends of both of them, lay them flat/flush, glue and bolt together?
2) Cut one to 4ft and connect it end-to-end via pocket joints?
Any Ideas, im open to suggestions...
Thanks in Advance
-Stinger
Stinger816 is offline   Reply With Quote
Old 01-07-2013, 12:41 PM   #2
Rewards Points: 150
Thanks in Advance
-Stinger
To save money and time, just buy and pick up a 2x6x12 from the store.
oodssoo is offline   Reply With Quote
The Following 2 Users Say Thank You to oodssoo For This Useful Post:
moneymgmt (01-07-2013), paul100 (01-07-2013)
Old 01-08-2013, 01:19 AM   #3
Rewards Points: 1,092
with the materials you listed, i don't think you can make it. it takes a lot of lumber to splice. as said, way cheaper/faster/stronger to buy the 12'.
Old 01-08-2013, 05:58 AM   #4
Framing Contractor
Thanks in Advance
-Stinger
If this is a serious post, why in the world would you not but a 12' piece? I hope your answer isn't that its because you want to use the material you have and save money.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-08-2013, 06:05 AM   #5
Rewards Points: 4,578
when your arbor fails 'cause you didn't want to spend another $ 15 for a 2x12, revisit your post most failures are caused by improper mtls, incorrect methods, &/or workers w/o any knowledge - you may just have hit the trifecta
Old 01-08-2013, 06:59 AM   #6
Rewards Points: 150
You guys really know how to welcome the newbies.
Maybe he didn't realize 12 foot lengths are standard. Maybe he can't figure out how to get a 12' board home in his Mini Cooper.....
silversport is offline   Reply With Quote
Old 01-08-2013, 07:09 AM   #7
Framing Contractor
That's what phones are for...to pick up and call a lumberyard. As far as getting it home on a mini cooper if he has one.....he can put it on top and tie it like everyone else you see doing with any vehicle..
Joe Carola
Old 01-08-2013, 07:19 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,186
Some people need a wake up call to realize they are doing something foolish, dangerous, uneconomical or impractical.
Coastal South Carolina
Old 01-08-2013, 09:27 AM   #9
Rewards Points: 13,450
A 2 X 6 would sag over a 12' span even with it's own weight.
Old 01-08-2013, 02:56 PM   #10
Rewards Points: 3,520
[QUOTE=Stinger816;1088312]Hello All, First time poster =D
Thanks in Advance
The only joint that would work would be a dove tail,if you already have the tools fine if not forget it,too expensive.
Canarywood1 is offline   Reply With Quote
Old 01-08-2013, 03:14 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
deleted
ddawg16 is online now   Reply With Quote
Old 01-08-2013, 09:03 PM   #12
he has a lamborghini, not a mini. you NEVER stack would on a lamborghini; it could fall on the chick in the passenger seat. besides, at top speed the wood starts to char.
Old 01-09-2013, 10:06 PM   #13
JOATMON
ddawg16's Avatar
Another one post wonder.......
Old 01-09-2013, 10:46 PM   #14
Funny how when they hear just how silly there questions sounds when they say it out loud they go away.
Old 01-10-2013, 07:05 AM   #15
Rewards Points: 3,130
Yeah, and it scares me the most with such questions are in the electrical forum.
Making an old fireplace insert more efficient Bed Rock HVAC 2 10-10-2012 05:39 PM
Making a melamine box secutanudu Carpentry 15 06-20-2011 02:51 PM
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
GE fridge (older model) motor(?) making a lot of noise as it runs, also leak! liileah Appliances 1 06-24-2008 11:32 AM
