Make Waterproof Barrier Between Plywood Wall And Concrete Foundation. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 01:16 PM   #1
Make waterproof barrier between plywood wall and concrete foundation.
I am in a flood zone and have a section of wood frame construction resting on a poured concrete slab. The outer edge of the studs and slab form a plane, i.e. the studs come up to the edge of the slab. Plywood is attached to the studs (to form the wall) and goes about 3 or 4 inches down over the side of the slab where it is tapconned to the slab. If we had a flood, water could work its way up between the plywood and concrete. I want to put something at the joint between the plywood and concrete to keep the water from coming in. What is the best solution for this - liquid nail? another small bit of concrete over the joint? ??? Is this a hopeless situation? I live in a hurricane zone and I'm talking about withstanding storm surge.
gbradley is offline   Reply With Quote
Old 10-24-2010, 01:48 PM   #2
concretemasonry's Avatar
Rewards Points: 2,640
Unfortunately, you did not post where you are hiding, so you can get is some general opinions.
If you are in hurricane country, you can expect to get substantial water inside unless it is minimal and for a very short term. Wood is organic and it will absorb moisture, swell, move and make it difficult for a "caulk/glue" last any period or amount of surge.
Most people recognize the power of Mother Nature and use the areas for materials and activities that can be moved or disposed of.
Often homes near coasts/rivers are built to provide lower level spaces on grade for parking, washer/drier and rec rooms that can be abandoned or items moved out temporarily. HVAC and furnaces are usually is attics because of flood damage to the controls. This concept works up to about 4' of water and concrete block "blow-out" panels are usually used for greater surges since they usually can take 8' of surge.
Dick
concretemasonry is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
distance from plywood shear wall to foundation pttcc Building & Construction 3 08-23-2010 11:18 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
