Maintaining Deck 4x4 Rail Post Inside Mounted With Fascia On Outside Of Rim - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 05:51 PM   #1
Maintaining Deck 4x4 Rail Post inside mounted with Fascia on Outside of Rim
What is the best way to mount post to rims joists/beam on inside so you can tighten fastener when wood shrinks in dry climates? Carriage Bolt over lag scres seems to be the only possible way with addess to the nut on the inside, unless you allow the bolt/screw to show thru fascia. Only other solution I can see is Titan Post Anchors but then you see this black metal instead of a wood post skirt.
ramllc is offline   Reply With Quote
Old 04-30-2011, 06:42 PM   #2
kwikfishron's Avatar
Rewards Points: 90
Welcome to the forum.
Carriage bolts is how I do it.
kwikfishron is online now   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 03:20 PM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-24-2007 12:34 AM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 08:55 AM
Deck post footings Outbacker Building & Construction 8 02-11-2006 06:20 PM
