Old 08-31-2010, 12:06 PM   #1
Main Beam Question for Cantilevered Deck
Hello, I am building a Cantilevered Deck. I have a question about the main beam. My deck is 20 feet long, but the longest wood that the hardware store had was 14 feet(which does not cover the length of the beam). Therefore, I am wondering if it is possible (and safe) to attach the 2x10s head on and if so, what areas should i put the beams head on. I know they have that flat piece of metal with the like 80 nails which goes into it which is 'supposed' to hold them together when putting them head on, but I am wondering hwo strong that will make it.
or is is possible to attach 4 lag bolts to one of the 4x4 posts and attach the segments of the beam there?
Thanks a ton,
Justin
xenos911 is offline   Reply With Quote
Old 08-31-2010, 12:41 PM   #2
Moderator
You can splice a built-up beam with the ends over a bearing post to get the required length. Consult your local building Department for a permit to be safe and continued coverage by your H.O.Insurance carrier for liability with a paper trail.
The basic safety Code for decks: http://www.lancova.com/deckinfo.pdf
Gary
Clothes taking longer to dry?
Old 08-31-2010, 01:11 PM   #3
Thanks for your reply gary
should 4 x 1/2" lag bolts be used for the post connecting the main beam?
Old 08-31-2010, 07:39 PM   #4
Moderator
It's all in the Deck Code, through bolts.
Gary
deck question toddj99 General Discussion 5 04-24-2010 11:12 PM
Deck Ledger Question Greg D Building & Construction 9 04-08-2010 08:57 AM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 10:15 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
