Main Beam Cut In Half - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2007, 11:13 PM   #1
main beam cut in half
i have a 100 year old house, i just noticed that my main beam is cut in half. when forced air was put in, they cut the main beam and there is a 2 to 3 foot space for the cimney to go up. on one side there are 2 steel posts with in 6 feet, and on the other they used 2x4 walls for the re-mainder of a 12 foot span. does this sound like trouble.
michaelmatchee is offline   Reply With Quote
Old 02-20-2007, 06:42 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It could be trouble by the sounds of it, but it is one of those things that someone would still need to see to confirm and advise a course or method of repair.....
Pics would help...
- Build Well -
Old 02-21-2007, 04:16 PM   #3
Chief Fungus Fighter
I'd get a structural engineer in ASAP. Make sure you inform the HVAC company who did the work you are doing this. Cutting a main beam in half is just flat out DUMB!
MoldBuster is offline   Reply With Quote
Old 02-21-2007, 06:59 PM   #4
I would still suggest getting someone to look at it onsite and confirm that it is the main beam and that it is structural....Older houses can fool you, especially if they have been altered or remodeled.
(Example: I have seen some old homes that have had issues with their structural beams. So new structural supports were added, rendering the old beam: as a peice of wood that no longer was supporting anything.)
The other bigger reason is that, once a professional opinion is given, if need be, temporary supports can then be installed.
After that is done the Home Owner should find out what company installed the HVAC work, even if it was installed prior to their ownership of the home.
I know cases where similar circumstances led to the original company being court ordered to pay for all costs of the repairs, even tho the work had been done 7 years earlier - at a time when someone else owned the property.... (I met one of the company owners -he wasn't happy)
....."believe it or not"...
- Build Well -
Old 02-22-2007, 12:10 PM   #5
Framing Contractor
"Main Beam cut in half"
That's all that has to be said to an Architect or Engineer, WHEN you call them!
Next is to talk to the HVAC MORON and let him know that he wont be getting paid and you will contact his insurance company.
Joe Carola
Joe Carola is offline   Reply With Quote
Jacking main beam/floor joists gshock Building & Construction 1 05-30-2007 09:17 AM
Should my home inspector have caught this? AllGoNoShow Building & Construction 9 02-09-2007 02:13 PM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 11:37 PM
Beam Load Ron Building & Construction 5 09-17-2006 07:28 AM
stick framing a shop sagging troubles on the main beam please help!!! weekendwork Roofing/Siding 8 09-24-2005 02:02 AM
