main beam cut in half
6K views 4 replies 4 participants last post by  Joe Carola
i have a 100 year old house, i just noticed that my main beam is cut in half. when forced air was put in, they cut the main beam and there is a 2 to 3 foot space for the cimney to go up. on one side there are 2 steel posts with in 6 feet, and on the other they used 2x4 walls for the re-mainder of a 12 foot span. does this sound like trouble.
#4 ·
I would still suggest getting someone to look at it onsite and confirm that it is the main beam and that it is structural....Older houses can fool you, especially if they have been altered or remodeled.
(Example: I have seen some old homes that have had issues with their structural beams. So new structural supports were added, rendering the old beam: as a peice of wood that no longer was supporting anything.)
The other bigger reason is that, once a professional opinion is given, if need be, temporary supports can then be installed.
After that is done the Home Owner should find out what company installed the HVAC work, even if it was installed prior to their ownership of the home.
I know cases where similar circumstances led to the original company being court ordered to pay for all costs of the repairs, even tho the work had been done 7 years earlier - at a time when someone else owned the property.... (I met one of the company owners -he wasn't happy)
....."believe it or not"...:detective:
