LVL Spans - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 05:39 PM   #1
LVL spans
I am removing a wall that splits a room that spans 24' , and is 22' long and carrys the weight of a standard 1/2 drywall over 2x6 ceiling ( 8') joists 24 " O.C., with a standard 2 x 6 rafter 24 "O.C. at a 4 & 12 pitch with a 40 yr. comp roof. what size LVLs do I need and how many sandwiched together ?
garrett1 is offline   Reply With Quote
Old 10-27-2010, 06:03 PM   #2
I've never installed an LVL without a lumber yard/engineer sizing it for the span
Go to a lumber yard & have them size your LVL
Old 10-27-2010, 08:37 PM   #3
Registered User
Rewards Points: 5,266
You may need a permit from your local Building Department for this structural change. They will want to see the Engineer's stamp and notes for the size of LVLs, strapping attachment for shear flow and uplift, post sizes, footings under the house or under the basement slab, possibly added shear panels of plywood to make up for the removed wall, etc. He/she will take liability for the beam during and after you install it to minimum safety code. The paper trail is good for your H.O. Insurance carrier also.
Gary
Deck Access Hatch rman1953 Remodeling 7 07-11-2010 06:44 PM
Is 2x6 cedar ok for 10 foot spans? kindrox Building & Construction 1 06-01-2010 01:05 PM
Horizontal spans Engus Building & Construction 7 04-16-2009 10:32 PM
Ceiling joists spans drywall in a basement? Indianer Drywall & Plaster 14 06-09-2008 03:51 PM
Teak floor joist spans tropic home Building & Construction 4 11-15-2006 11:52 PM
