Lvl Sizing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 05:15 PM   #1
lvl sizing
i am remodeling a cottage and removing a lot of walls what size lvl beam do i use for a 24' ridge beam 3 1/2 pitch in New York stATE i will also be adding a beam at mid span
TOMF is offline   Reply With Quote
Old 11-16-2009, 05:21 PM   #2
You will need to consult with an Engineer or someone else to size your beam
For my 24' wide garage I would have needed (3) 16" LVL's to have a ridge beam with an open floor plan on the attic without rafter ties
This can vary widely based upon the design & support
There is no rule of thumb or guessing, it needs to be properly sized
Old 11-16-2009, 06:10 PM   #3
joed's Avatar
Rewards Points: 12,440
Most beam suppliers will size the beam for you . Go to your local lumber supplier with the details. They should be able to size it.
Old 11-16-2009, 08:17 PM   #4
Household Handyman
Rewards Points: 1,408
Along with the other two statements, when I built my garage in '96 and was putting up 12' wide garage doors, then when I remodeled my deck and wanted to get rid of those ugly 4x4 post every four feet, the local builders supply did not spec out the LVL beams. I had to call the LVL supplier, which the building supply house gave me, to get the LVL beams spec'd out. The supplier/wholesaler had no problem with helping me on these two projects. Actually, I sent them detailed drawings on of each project and they drew in the beams for me. This may be one way to get yours done. Good Luck, David
Sizing a furnace - can't find one small enough Jim W HVAC 30 05-13-2009 08:38 PM
Help sizing a gas line stubborn1 Plumbing 3 11-30-2008 11:38 AM
DWV sizing for kitchen sink KPH120 Plumbing 11 12-30-2007 08:40 PM
LPG pipe sizing information steve1234 Plumbing 1 12-14-2007 10:18 PM
Sizing vs. matching paint for wallpaper alvanos Painting 2 05-22-2006 05:27 PM
