Old 08-27-2012, 07:52 AM   #1
lvl nailing pattern
Prescribed nailing pattern for lvl 1 3/4" x 14" x 17' (3)
J Starcevich is offline   Reply With Quote
Old 08-27-2012, 08:19 AM   #2
the Musigician
DangerMouse's Avatar
lvl nailing pattern
Is this a question? This is not Google.....
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 08-27-2012, 10:50 AM   #3
lvl nailing pattern
I wouldn't use nails at all. The ridge beam for my log home is tripled 1-3/4 LVL, 12-inch x 36 feet. I don't recall the brand name, but I used some special hex-head screws designed for this purpose. Probably overkill, but I used three every two feet, then offset the same spacing on the other side. I have no idea what the code pattern is, because the inspector didn't even look at what I had done. There is no framing inspection here.
Nailing Rigid Foam Boards to Plywood Buscador Roofing 5 02-05-2012 07:22 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 11:37 AM
Drip Edge/Gutter Apron Nailing Pattern? echase Roofing 1 03-17-2010 12:09 AM
Crown moulding nailing and blocking pattern Klawman Carpentry 2 01-13-2010 12:22 PM
Shingle Pattern gilberte Roofing 7 09-05-2005 04:37 PM
