LVL Or I-joist Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 02:47 PM   #1
LVL or I-joist header
Wondering what preferences are here. Floor is 11 7/8" TJI. There is a 4' wide staircase cutout that runs parrallel to I-joists right in the center of the floor. Doubled up the TJIs (with blocking between them) on either side of the staircase. Now I need a double header located directly above the bottom of the staircase for two more TJI to attach to.
Do you guys prefer to use LVL for this header, or just a double TJI with blocking? We always used either 2x lumber or LVL for this, but I've got extra TJI, if that will work. I've also got extra rimboard that I could double up.
Cache is offline   Reply With Quote
Old 07-22-2008, 04:25 PM   #2
Registered User
Termite's Avatar
Rim board is a no-no, unless it is Timberstrand brand, which can be used in some span applications. Most rim board is not able to be used in span.
There are I-joist options, although you need to consult your supplier. Usually you'll have to use web fillers, etc.
Personally, I'd use LVL.
Old 07-22-2008, 09:23 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Try this link its worth the reading. BOB http://www.ilevel.com/literature/TJ-9001.pdf
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 08:55 AM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
