LVL Or Glulam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 08:21 AM   #1
LVL or Glulam
I am trying to get info about spanning a 30 ft load bearing reach with an LVL or Glulam with no supports is this possible?? This is in a house under the second floor where the floor joysts are married together. Now there is a 2x4 poorly framed wall holding it upbut the home owner wants it (the wall) removed
Amoroso is offline   Reply With Quote
Old 07-18-2012, 08:31 AM   #2
If you aren't going to be able to put any supports/posts underneath of the beam... How do you think it is going to stay up??
CopperClad is offline   Reply With Quote
Old 07-18-2012, 08:32 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
you will need an on site engineers' evaluation for a 30' span. that is a long ways with a lot of unknown variables to even get close to answering your question over the internet.
hand drive is offline   Reply With Quote
Old 07-18-2012, 09:24 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Like the guys above said, this is a DIY project to put together...but not a DIY to calculate....besides the beam, you have to take into accunt the footing under the posts at each end....
30' Is a long span....might want to also consider PSL beams. To give you a relative idea....my garage is 20' wide...and I have a 7x16 PSL beam down the middle of my garage....and that is only 20'.
Old 07-18-2012, 09:51 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
30' span will most likely be a steel I-beam. You're going to have to pay an engineer to spec it and the end posts.
Like I always say, make sure you follow the load to make sure the posts are supported all the way down to the foundation.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-18-2012, 11:56 AM   #6
Framing Contractor
You have no choice but to have an architect or engineer spec a beam for you. Your question cannot be answered here.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
PaliBob (07-18-2012)
Old 07-18-2012, 12:24 PM   #7
Rewards Points: 1,300
I am going to guess that this is the same project as this one from the other day. http://www.diychatroom.com/f14/lvl-150659/ Nobody here is qualified to give you the answer you need to hear (aside from hire an engineer) or crazy enough to give you the one you want to hear
danpik is offline   Reply With Quote
12' span glulam beam? instantbradley Building & Construction 11 12-18-2011 09:35 PM
Hanging loft from glulam beam, pics inside. wackerjr Building & Construction 20 01-05-2011 08:55 PM
Shortening a glulam timber LarryBobo Introductions 1 08-29-2010 11:53 PM
Req'd treated sill plate if I use Glulam seat ? yddkdd Building & Construction 4 07-16-2009 09:55 PM
Repair a cedar glulam joeblowofidaho Carpentry 8 06-06-2009 03:10 PM
