Old 10-29-2011, 11:35 AM   #1
Lvl beams
Lvl beams have a nailing pattern could you tell me what the pattern is?
ROB SYME is offline   Reply With Quote
Old 10-29-2011, 11:40 AM   #2
Framing Contractor
Lvl beams
http://www.westfraser.com/products/L...6.06_FINAL.pdf
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-29-2011, 01:24 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Lvl beams
whenever possible go with teh manufacturers specs. more often than not i either go rows of 5 spikes 12 o.c using hand spikes not gun spikes... hand spikes are heavier gauge and they will actually sink. most framing guns cant sink spikes in lvl because of how hard it is plus the hand spikes will draw it together
woodworkbykirk is offline   Reply With Quote
Old 10-29-2011, 05:44 PM   #4
"Nail-Bender"
Lvl beams
Yeah -
Hand spikes -
Sometimes we use "clamps" - of some sort.
rossfingal
rossfingal is online now   Reply With Quote
Old 10-29-2011, 08:36 PM   #5
Framing Contractor
Lvl beams
They don't HAVE to be hand nailed. It depends what type of gun you have. If a few nails don't sink....that's what you use your hammer for. I've never nailed lvl's by hand.
Also..I always glue lvl's together.
Joe Carola
Old 10-29-2011, 10:01 PM   #6
Lvl beams
sorry ,should have mentioned im in canada the lvl we get is hard as a rock. ive used a bunch of different framing guns on lvl and nothing has sunk. used paslode, paslode impulse, porter cable, dewalt, old school hitachi (high quality) and ridgid.. some say max nailers sink no problem. i believe its the diffence in quality of the wood. 50% of canada's lumber gets sent to the states.. and we never see american lumber soo
Old 10-29-2011, 11:17 PM   #7
robertcdf's Avatar
Lvl beams
Depends upon the size of LVL... I've seen LVL from 5.5" - 18"... Refer to the specs from the designer because I've seen different specs on the same size material. More information is necessary.
robertcdf is offline   Reply With Quote
Pergola Notched Cross Beams Are Bending and Warping dcunited122 Building & Construction 10 06-25-2012 07:20 AM
Connecting Beams And Post JoeLena Building & Construction 5 01-01-2011 05:32 PM
Wiring on exposed wood beams - Ontario Canada djgap Electrical 5 09-29-2010 01:41 PM
Deck project - Shim beams or joists? jcims Carpentry 1 08-08-2009 09:02 PM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 03:00 AM
