LVL Beam Sizing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 07:03 PM   #1
Question
LVL Beam sizing
I am opening up a home floor plan by removing partitions. The partitions support the ceiling joists (2x6 @ 16" oc)
I would like to size an upset beam to support the ceiling joists.
The Beam would be 16' long and has a load of 150 PLF.
I prefer to use LVL or equal material but would be open to suggestions.
Also, the end load is 1200 LB with 4" bearing and I have to taper the end to fit it into the space below the roof deck.
The slope of the roof is 3/12 and the minimum depth at bearing would be 4".
I would appreciate any suggestions.
Thank you
Bill
Billdherup is offline   Reply With Quote
Old 03-11-2009, 08:32 PM   #2
joed's Avatar
Rewards Points: 11,614
Go to your local supplier. They will size the beams for you. Every manufacturer has their own table to match their beams.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Lan beam sizing orcasrob Carpentry 5 08-05-2008 10:05 PM
sizing a flitch beam for small space gorf Building & Construction 2 08-04-2008 09:04 PM
Beam Sizing Riddler Carpentry 14 08-05-2006 01:46 AM
