LVL Beam / Load Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 09:51 PM   #1
LVL Beam / Load beam?
I'm looking to finish my basement. The area is rather small and in order to open up the area I'm looking at removing the support pole placed in the middle of the room. The pole is currently rated not to exceed 14,800 lbs. The pole supports two LVL beams ( 11' 3/4" H x 13' 10" L x 1' 3/4" W....dimension for each beam). One side of the LVL beam is placed on the foundation and the other end is placed on top of two 2x4s sandwiched together.
Will placing two additional LVL Beams (same dimensions) be enough to remove the pole? Do I need to attach the new LVL beams to the existing beams. If so, what is the best methods to use. Do I need to jack up the beam prior to placing the new beams in place. Any help with this matter would be great. I'll attach photo if necessary. Thanks
tarr618 is offline   Reply With Quote
Old 01-28-2009, 10:57 PM   #2
Can you restate your beam measurements please?
Pictures would help. I doubt you'll be able to remove the pole.
Reilley is offline   Reply With Quote
Old 01-29-2009, 05:27 AM   #3
Rewards Points: 5,336
No, you can't do that.
Ron
Old 01-29-2009, 07:55 AM   #4
So you want to span almost 28' without a pole?
In my garage -I spanned 24' - required triple 14" beams
This was supporting a great room above, and a walk up attic
My beams were engineered - I actually went with triple 16" instead
Most lumber companies can give you a size on an LVL beam
But based on my size you would be looking at 16-18" beams
That's if it's possible - depends upon the load, number of floors
This is the main support for your house & should be engineered for the load. My building Dept required engineered stamp
You can't simply wing it, this is a main support & would be a catastrophic failure if undersized
Old 01-29-2009, 09:34 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
The way I read it is that the beam comprised of a double LVL. The total length of the beam is 13'10". There is a post in the middle and the spans are half of the 13'10" or 6'11".
Currently the beam is bearing on the foundation on one side, a post in the middle (the one he wants to remove), and a double 2x4 on the other side. My guess is this double 2x4 is tied into a wall.
The OP wants to take out the post in the middle and make a single span of 13'10".
This should be completely doable but to size it properly, you need to talk to someone that understands loads. Simply doubling it won’t work. Many lumberyards offer the beam spec service for free.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-29-2009, 03:06 PM   #6
I'm sorry, here is a little clearification. What Clutchcargo said is correct. The width of the room is 13'10". The measurement I provided on the LVL was one of the beams. The two LVL's are sandwiched together. Total width of the beam is 3' 1/2". The side with the two 2x4's is attached to an unfinished wall.
With the correct LVL beam do I need to jack up the beam prior to placing the new beams in place or can I attach the LVL's together and simply remove the pole? Thanks for the help. I'll attach photo this evening. Thanks
Old 01-29-2009, 03:14 PM   #7
That's a much better span distance
You would need to go to a lumber yard & have them size the beam
Mine did it for free, I did buy my LVL's from them
They want to know what bears on the beam
Walls above, total stories of the house, roof area/way it slants
They will be able to tell you if you can just sandwich another beam or two or if you will need a bigger beam
I needed (3) 16" LVL's to span 12' with a wall above (walk up attic) & roof load
Old 01-29-2009, 05:44 PM   #8
I have gas!
You may be able to just laminate the laminated beam with 1/2" steel plate on each side. A structural engineer or someone that knows how to run the software will be able to spec that.
ScubaDave, 3x16" LVL seems overkill for a 12' opening. Is there a point load on that too?
Old 01-29-2009, 06:16 PM   #9
That's the engineered size, this is a side view of the addition
The beam in question is where the 17' & 19' lines meet
It is supporting the attic wall & 1/2 the floor above
It then supports 1/2 the Cathedral roof & 1/2 the attic roof
Old 01-29-2009, 07:38 PM   #10
I have gas!
I see, you have a lot of tributary floor load.
Old 01-29-2009, 08:01 PM   #11
Clutch,
Would steel be cheaper than LVL and which would be easier to install? How would I go about contacting someone to run the numbers? Would a local building supply be able to help.......and last question....I'm I getting into an area that I should pay someone else to do the job. I just keep looking at it thinking that I've tackled tougher projects, I just need to know I'm placing enough support for the space/weight. Thanks for the help
Old 01-29-2009, 10:30 PM   #12
cocobolo's Avatar
Rewards Points: 5,788
Have you considered taking your information to your local building inspector's office? I'm sure he will give you good and correct advice.
The job itself is not difficult. You just need to be certain it has adequate strength and proper bearing at both ends.
cocobolo is online now   Reply With Quote
Old 01-30-2009, 07:28 AM   #13
I have gas!
tarr, could you post some pictures?
Old 01-30-2009, 08:16 AM   #14
clutch----I'll place them online tonight---thx
Old 01-30-2009, 09:25 AM   #15
joed's Avatar
Rewards Points: 12,396
Any supplier who sells the LVL should be able to size the beam for you.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
Ridge Board vs Beam carrying load fauer Building & Construction 3 01-19-2008 09:39 PM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
