Lvl 30 Ft Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 03:10 AM   #1
lvl 30 ft span
on a 20 x 30 pole barn, 6"x6" post every 10 ft for a total of 8 posts , 3 on each side and 4 across the back, can I have front 30 ft. span open with no posts and what size lvl and how many should I use.Its a basic no walls pole barn with just a 4/12 pitch roof with 2x8 rafters and 2x8 joist on 2ft centers.
doug1974 is offline   Reply With Quote
Old 05-24-2011, 07:03 AM   #2
Framing Contractor
Rewards Points: 120
If the trusses will bear on that beam, the answer is No Way! If they run parallel to that beam, then I think it might be possible. There are other factors to consider other than just the loading though.
sixeightten is offline   Reply With Quote
Old 05-24-2011, 07:37 PM   #3
Carpenter
dtsman's Avatar
Read the PDFs at this link. The last PDF will be most helpful. They will help you to make the right decision.
http://www.gp.com/build/product.aspx?pid=1392
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 10:45 PM
Platform across a 9 foot span Hogan-s Carpentry 1 09-19-2008 07:46 AM
