LP Smartside Advice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 07:33 PM   #1
LP Smartside Advice
Greetings,
I'm designing and building a small (16' X 14') cabin in western wisconsin. My intent is to sheath the walls with OSB and then side the cabin with LP Smartside Grooveless panels. I would then add LP Smartside Trim to simulate board and batten construction.
A) What thickness OSB do I want to use for the sheathing?
B) What should I use as a vapor barrier in between the Sheathing and the Smartside siding?
C) If the Smartside trim "battens" are 4" wide is it permissable to nail them to the face of the Smartside panels or do I need to hit studs? The studs are on 16" centers and I think I want the battens on 12" spacing so hitting the studs will not work unless I block everywhere.
Rendering of design follows. Advice greatly appreciated.
Thank you.
Dave
Davef_dci is offline   Reply With Quote
Tags
board and batten , lp smartside , siding
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 09:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 06:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
