Lowering A Ten Foot Ceiling Just Two Feet From Edge All Around The Room To Eight Feet - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 08:37 PM   #1
lowering a ten foot ceiling just two feet from edge all around the room to eight feet
I want to drop the ten foot ceiling to eight feet that is only on the edge. Keep in mind I want to keep the center of the room 10 feet?
talljohnc is offline   Reply With Quote
Old 10-29-2011, 08:59 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
so you want to build a soffit., simple enough, easiest way to do this is with light gauge 1 5/8" steel stud. it will be much straighter than trying to use 2x2's which will warp like crazy.. this is proably the only time i like framing with steel stud... all you need to do is create a level line on the wall at 8' and carry it all the way around the room. same for how far off the wall it comes.. mark this line on the ceiling.. from there you jus tneed to build ladder frames and connect them to the ceiling and then drywall it
woodworkbykirk is offline   Reply With Quote
Old 10-29-2011, 08:59 PM   #3
Msradell's Avatar
Rewards Points: 350
So what's your question?
With what you gave us it's basically going to be impossible to give you any device. To start with pictures would help and then a description of what is above this room, room size, etc.
Msradell is offline   Reply With Quote
Ceiling is very hot in the living room 3caddydaddy Insulation 4 06-22-2011 02:55 PM
how to build toy shelf near ceiling of kids room Kimmoski Carpentry 2 06-22-2011 07:22 AM
What size Ceiling Fan for this room? Goldglv General DIY Discussions 0 05-15-2011 09:38 AM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-24-2006 11:23 PM
