Lowering Basement Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2009, 10:10 PM   #1
artlover13060's Avatar
I am going to be installing a sheetrocked basement ceiling. I can't apply furring strips to the floor joists because of obstructions, such as HVAC ducts, etc. If I drop the ceiling to 8' I can avoid the obstructions. I plan to do this by running a nailer around the room, then using joist hangers and 2 X 4s. I know that I will have to add supports between the 2 X 4s and the joists so that the ceiling won't sag. Do I also need to add bracing between the 2 X 4s? If so, at what spacing?
artlover13060 is offline   Reply With Quote
Old 10-26-2009, 11:15 PM   #2
Rewards Points: 5,336
You are using the 2x4's as ceiling joists so 16" on center would be the spacing I would use.
Ron
Old 10-26-2009, 11:22 PM   #3
Registered User
Rewards Points: 4,924
As Ron said " 2x4's as ceiling joists so 16" on center"---- with 7'6" maximum span.
Be safe, Gary
Old 10-26-2009, 11:51 PM   #4
ouch my thumb
i like using metal instead of wood for bulkheads and ceilings. it doesn't shrink or warp like wood- stays straight.
you could also use hat channel and metal stud system. they also make a grid you can hang drywall on - goes together like an acoustic ceiling- commercial drywall/metal stud supplier should carry it.
heres some ideas
http://www.armstrong.com/commceiling...ticle8536.html
indy500 is offline   Reply With Quote
lowering ceiling to 8 feet level mirico Carpentry 4 10-24-2009 09:24 AM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 08:24 AM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
