-   -   Lowering Basement Ceiling (http://www.diychatroom.com/f19/lowering-basement-ceiling-56017/)
artlover13060 10-26-2009 10:10 PM
I am going to be installing a sheetrocked basement ceiling. I can't apply furring strips to the floor joists because of obstructions, such as HVAC ducts, etc. If I drop the ceiling to 8' I can avoid the obstructions. I plan to do this by running a nailer around the room, then using joist hangers and 2 X 4s. I know that I will have to add supports between the 2 X 4s and the joists so that the ceiling won't sag. Do I also need to add bracing between the 2 X 4s? If so, at what spacing?
Ron6519 10-26-2009 11:15 PM
You are using the 2x4's as ceiling joists so 16" on center would be the spacing I would use.
Ron
Gary in WA 10-26-2009 11:22 PM
As Ron said " 2x4's as ceiling joists so 16" on center"---- with 7'6" maximum span.
Be safe, Gary
indy500 10-26-2009 11:51 PM
i like using metal instead of wood for bulkheads and ceilings. it doesn't shrink or warp like wood- stays straight.
you could also use hat channel and metal stud system. they also make a grid you can hang drywall on - goes together like an acoustic ceiling- commercial drywall/metal stud supplier should carry it.
heres some ideas
http://www.armstrong.com/commceiling...ticle8536.html
