Lowering Backyard Level & Window To Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 08:53 PM   #1
lowering backyard level & window to crawl space
Hi
I have a very small yard (maybe 200 sqft... in Brooklyn, NY this is great)
it is flanked from three sides: neighbors backyards on two sides and on other neighbor's backyard in front. I have a three story house with a crawl space of about 5'... I have many issues with the perimeter wall to the backyard - it was not properly waterproofed (the house is 100yrs) and it has water sipping from it when it rains and it is crumbling so the floor next to that wall is slanting real bad. I was thinking about lowering the level of my backyard to allow for a small window in the crawl space and to fix that wall at the same time. (no windows now - it is underground)
1. Anyone has any idea if I will need a permit for lowering the backyard level only? (I know I need one if i want to add a window)
2. If I break the concrete slap in my backyard and just start digging, right against that outside wall to my backyard, could I collapse my entire house??? I am serious.
greenpointer is offline   Reply With Quote
Old 03-13-2011, 09:11 PM   #2
Rewards Points: 5,336
Post some photos of the issues.
Ron
Old 03-14-2011, 07:40 AM   #3
1) Call and ask.
2) You mean like a patio? That shouldn't bother the house. What you should find is that the exterior wall of the crawlspace goes under ground for a few feet, and rests on a footer. That's a wide piece of concrete, probably twice as wide as the wall.
Don't make your backyard lower than everyone around you though, or you'll end up with a neighborhood retaining pond!
pyper is offline   Reply With Quote
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 05:58 AM
water in crawl space need advice puma80 Building & Construction 2 04-08-2010 10:07 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 08:26 PM
