Low Slung Deck Details - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2007, 03:22 PM   #1
low slung deck details
Hello all,
I am planning a yard-hugging deck, with the main portion just a single step off grade. This would make it in the 6-8 in. height. Materials are concrete piers, PT framing, and some flavor of composite decking (not decided yet).
I suppose there are ventilation issues I need to think about, but I'm not sure how to pull off good vent. being so close to grade. One mfgr. website calls for 2" between bottom of joist and grade.
Are there any other issues I need to take into consideration with this type of install? Or is it not worth the effort? That is, should I just build for ventilation, and live with a second step up from grade?
Thanks for your input!!
houser
houser is offline   Reply With Quote
Old 07-05-2007, 04:15 PM   #2
concretemasonry's Avatar
Rewards Points: 2,654
Make the grade slope away from the house and put down a durable 10 mil vapor barrier you can walk on and work over. You certainly do not want to try to put it down after the beams and joists.
concretemasonry is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
deck questions robphelan Carpentry 6 06-25-2006 06:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 10:37 PM
