Low Profile Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 10:26 AM   #1
LDO
Low Profile Deck
I would like to build a 12x12 low profile deck. My plan is to use doubled 2x8s for the beams. Is there a calculator that tells me how many I'll need and how many footings i'll need? My plan was to place the beams directly onto the footings using 3 inch support hardware. Would a 1.5 foot overhang on all four corners be ok?
Can someone point me in the right direction?
Decking will be 2x6s
Thanks.
LDO is offline   Reply With Quote
Old 10-19-2008, 10:42 AM   #2
re: Low Profile Deck
First off I'd suggest one of the best places to get help with structural member sizing is your local lumber yard. Most large suppliers have staff that are trained in sizing basic members.
Secondly, I remind folks that a standard deck is really no different than framing a house. If you understand how to frame a house floor then you can use the same sizing for the deck.
The big question here is how are you going to frame the deck? Are you implying that the beam sits on your footings and the joists frame into the beam so that the joists and beams are at the same elevation?
If so I'd use a double 2x8 beam sitting on 3 footings (footings spaced at 1', 6' and 11'). Then you can use joist hangers to hang 2x8 joists from the beam. With a 12' span you'll need to space the 2x8's at 12" O.C. Even at 12" O.C. I think the deck may be quite flexible.
If it were my deck I'd use 2x10's.
HCI Blogger is offline   Reply With Quote
Old 10-19-2008, 12:06 PM   #3
I would steer away from double anything in a deck situation. All that does is allow water to get in a place to sit and rot.
Go with one board and use a bigger board like a 2x10 PT.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-19-2008, 03:36 PM   #4
LDO
HCI,
yes, the beams and joists would be at the same elevation. So you think that I should use 2x10s instead of 2x8s?
If so, and if I read your comment on the footings correctly, I would need 9 footings all together correct?
This is my first project like this so let me apologize now for stupid questions.
Old 10-21-2008, 01:00 AM   #5
Custom Deck Builder
BuiltByMAC's Avatar
Ground level deck, yes? You're trying to keep it low enough to be a single step down to the ground, yes?
12x12 deck, ground level:
4 footings total - outer beam supported at 2' and 10' , house side beam supported at 2' and 10' - total of 8' span for beams.
If you want to overbuild (nothing wrong w/ that), use 3 footings per beam - 1', 6', 11'
Doubled 2x8 beams are fine, wrap the tops w/ 4" wide flashing tape to prevent rot from occurring at seam.
2x8 Joists, be they Hem-fir or SYP, spaced 16" o.c. hung from beam w/ Simpson LUS 28Z hangers will span 12' with no problem.
One calculator available to you is this:
http://www.awc.org/calculators/span/...rcalcstyle.asp
Take any advice you get online w/ a grain of salt...anonymity breeds overconfidence in the ability to dispense advice.
Mac
Built By MAC
BuiltByMAC is offline   Reply With Quote
Old 10-28-2008, 08:24 PM   #6
Cool
Deck Framing question
Schaumburg il, Says I cant use Bugle screws in the framing.
So what am I suppose to use. I ahve wasted alot of money in special green deck screws from lowes and then the inspector says I cant use bugle screws. Are nails my only optio?
I am at a halt in my project. Until this is fixed. But how do I fix this problem?
Iceman 1972
iceman1972 is offline   Reply With Quote
Old 10-28-2008, 09:28 PM   #7
Iceman 1972
Ask the inspector what is allowed.
Old 10-30-2008, 11:56 AM   #8
I DID AND HE IS A ******* AND DOESNT TELL ME ANYTHING. SAYS I CANT BUILT YOUR DECK FOR YOU.
IM ON MY OWN. THANK GOD FOR GOOGLE.i FOUND OUT NO FRAMING JOBS SHOULD EVER BE DONE WITH SCREWS. I WISH I NEW THAT ABOUT 150.00 AGO.
WHAT A WASTE
ALWAYS BUILD DECK FRAMES WITH NAILS.
I LEARNED THE HARD!!1
Old 10-30-2008, 12:00 PM   #9
Mac
Built By MAC
I just built a 20 x 20 ground level deck and used pre cast stones that i got from lowes.
i used 2 6 x 16's for joists. and regular decking on top. Its really fast and easy.
I also found I could use 4x4 post cut to size to level things. Its under code
Old 10-30-2008, 01:24 PM   #10
Structural Engineer
WHAT A WASTE
This is false. You can frame with screws. You just need to make sure you're using the right size and material type. Also make sure you can provide manufactures info for the screw you're using. All manufactures publish info on shear, tension and pull-out capacities for their fasteners.
wildcat is offline   Reply With Quote
Old 10-30-2008, 01:46 PM   #11
BUILDER / REMODELING CONT
buletbob's Avatar
I agree! BOB
Old 10-30-2008, 04:43 PM   #12
Exactly.
Screws are less likely to pull out of the wood. When I have to rip out a deck with screws I cringe. With nails I just get the "big" hammer.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
