Lots Of Cold Air Coming From Missing Piece Of Sill - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 05:57 AM   #1
Question
Lots of cold air coming from missing piece of sill
I have to replace some of my basement ceiling due to an aquarium leak on the first floor. I could feel some serious cold air coming through one of the joist runs. I ripped it out until I discovered that one section of the sill was removed in order to run some wiring. I can see the exterior brick. The house was built in about 1930's. My neighbour says his house is double brick, not sure about mine.
So I estimate it to be about 8 inches high and 20 inches across. I was thinking I would cut a piece of pink insulation board with cut out for the wires, use spray insulating foam sealant for the edges.and then place a fiberglass batt in as well.
Or should I try to fill part of it with wood?
ccathy247 is offline   Reply With Quote
Old 12-18-2010, 06:20 AM   #2
Rewards Points: 1,216
Depends where you live, if it was me I do do what you said just to get me through the Winter and in the Spring I would have plenty of time to open it back up and make the permanent repair.
COLDIRON is offline   Reply With Quote
Old 12-18-2010, 06:27 AM   #3
the Musigician
DangerMouse's Avatar
Not seeing the actual area, I'd say you have a good grip on how to seal it up.
DM
Old 12-18-2010, 06:30 AM   #4
Thanks ColdIron
Eek! that was going to be my permanent repair. Have owned the house for 5 years. Husband has his TV chair above this area and complains about cold floor. The ceiling I ripped out was pretty old. I am looking for the best way to keep the cold air out.
Old 12-18-2010, 08:15 AM   #5
Rewards Points: 5,336
You don't mention any joists resting in this area, so the assumption is this sill plate runs parallel to the joists. Since the rim joist is still above this sill, I would personally set in a wood sill over a sill gasket and foam the gaps.
Ron
Warm and cold air only coming out of 4 vents in whole house petergreen HVAC 5 02-03-2010 03:54 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 06:40 PM
shower stall with hole (cold air coming in) mcvane Plumbing 1 02-08-2009 10:41 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
