Old 03-28-2012, 11:53 AM   #1
loose vinyl siding
i can pull the bottom portion of vinyl siding away from house, how can i repair without removing.
jazzsiepowe is offline   Reply With Quote
Old 03-28-2012, 12:14 PM   #2
the Musigician
DangerMouse's Avatar
loose vinyl siding
It's next to impossible to fix this without removing it and putting it back on right. However, there may be a way to "temporarily" fix it with glue, nails or screws, etc. The best way is still the right way. It MAY just be able to be "snapped" back to the starter strip, if it's the bottom run? Hard to say without seeing it first hand.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 03-28-2012, 12:27 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
loose vinyl siding
Zip Tool is your vinyl siding repair friend: http://homerepair.about.com/od/termsst/g/ziptool.htm
Definition: The zip tool or siding removal tool, is a small hand held tool with a specially shaped curved blade used to install or remove a strip of vinyl siding.
HD Link: http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
- Build Well -
The Following 2 Users Say Thank You to AtlanticWBConst. For This Useful Post:
kj6887 (03-30-2012), PaliBob (03-29-2012)
Old 03-28-2012, 12:47 PM   #4
the Musigician
loose vinyl siding
True, however...... (see above quote.) No easy way around it that I know of.
DM
Old 03-28-2012, 03:00 PM   #5
loose vinyl siding
Yes, they may have to remove some sections to re-nail, and then use the zip tool to put it all back together.
- Build Well -
Old 03-28-2012, 03:33 PM   #6
the Musigician
loose vinyl siding
As always, pictures of your exact situation will help us to help you.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
kwikfishron (03-28-2012)
Old 03-28-2012, 09:38 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
loose vinyl siding
either it just needs to be zipped back into place or the panel was installed too loosely so it cant properly be locked back into the starter without pulling up on the first panel by unlocking hte upper peice and renailing
woodworkbykirk is offline   Reply With Quote
Old 03-29-2012, 01:42 AM   #8
loose vinyl siding
If it is to lose so also may be the pieces above it and they may all need renailed tighter.
mae-ling is offline   Reply With Quote
Old 03-29-2012, 07:24 PM   #9
loose vinyl siding
the only way the above piece is causing a lower piece to be loose is if its nailed too high which is pulling up on the lower piecee. in turn making the it so the lower piece cant be locked into the starter channel
Old 03-29-2012, 08:22 PM   #10
firehawkmph's Avatar
loose vinyl siding
If it's just the bottom panel that's loose, carefully remove the starter strip and move it down just a bit so the panel when zipped back onto the starter will have no slop in the bottom between it and the starter. If it was put on when the house was new, it is common for the panel that is attached to the mud sill and/or the second floor band joist to come loose after the wood dries out and shrinks slightly in height. Drive through a development that is more than a few years old and you'll see plenty of loose panels flapping in the breeze.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 10:02 PM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-14-2009 12:16 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
