-   -   loose vinyl siding (http://www.diychatroom.com/f19/loose-vinyl-siding-138523/)
jazzsiepowe 03-28-2012 10:53 AM
loose vinyl siding
i can pull the bottom portion of vinyl siding away from house, how can i repair without removing.
DangerMouse 03-28-2012 11:14 AM
It's next to impossible to fix this without removing it and putting it back on right. However, there may be a way to "temporarily" fix it with glue, nails or screws, etc. The best way is still the right way. It MAY just be able to be "snapped" back to the starter strip, if it's the bottom run? Hard to say without seeing it first hand.
DM
AtlanticWBConst. 03-28-2012 11:27 AM
Zip Tool is your vinyl siding repair friend: http://homerepair.about.com/od/termsst/g/ziptool.htm
Definition: The zip tool or siding removal tool, is a small hand held tool with a specially shaped curved blade used to install or remove a strip of vinyl siding.
HD Link: http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
DangerMouse 03-28-2012 11:47 AM
True, however...... (see above quote.) No easy way around it that I know of.
DM
AtlanticWBConst. 03-28-2012 02:00 PM
Yes, they may have to remove some sections to re-nail, and then use the zip tool to put it all back together.
DangerMouse 03-28-2012 02:33 PM
As always, pictures of your exact situation will help us to help you.
DM
woodworkbykirk 03-28-2012 08:38 PM
either it just needs to be zipped back into place or the panel was installed too loosely so it cant properly be locked back into the starter without pulling up on the first panel by unlocking hte upper peice and renailing
mae-ling 03-29-2012 12:42 AM
If it is to lose so also may be the pieces above it and they may all need renailed tighter.
woodworkbykirk 03-29-2012 06:24 PM
the only way the above piece is causing a lower piece to be loose is if its nailed too high which is pulling up on the lower piecee. in turn making the it so the lower piece cant be locked into the starter channel
firehawkmph 03-29-2012 07:22 PM
If it's just the bottom panel that's loose, carefully remove the starter strip and move it down just a bit so the panel when zipped back onto the starter will have no slop in the bottom between it and the starter. If it was put on when the house was new, it is common for the panel that is attached to the mud sill and/or the second floor band joist to come loose after the wood dries out and shrinks slightly in height. Drive through a development that is more than a few years old and you'll see plenty of loose panels flapping in the breeze.
Mike Hawkins:)
