Loose Sheet Metal Screws - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 04:39 PM   #1
Loose sheet metal screws
I have metal storm doors on my house that are over 20 years old. In some of the doors, the sheet metal screws that hold the top hinges will still screw into the door but will not pull down tight anymore. The screws are the largest that Home Depot carries. Is there some trick that I can use to cause these screws to pull down tight?
Thanks.
harrysanders is offline   Reply With Quote
Old 05-30-2010, 05:20 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Yes there is a way to do this, many in fact, here's one possibility. Use JBWeld steel filler and mix the 2 parts together, then stuff as much as you can in the holes. When dry, gently screw in the screws to rethread the epoxy. Then mix more JB and use it to glue the hinge to the door as well as you mount them again. There are other ways to tackle this as well.
DM
Old 05-30-2010, 06:10 PM   #3
Thanks.
Old 05-30-2010, 08:07 PM   #4
I dont know if this works for metal but when a screw going into wood is stripped i make some thin splinters with a shake shingle and pack the hole with it then the screw has something to bite to (toothpicks also work) good luck
mark2007 is offline   Reply With Quote
Old 05-30-2010, 09:16 PM   #5
Maybe move to a new spot in the sheetmetal and bite into fresh metal?
fpeftw is offline   Reply With Quote
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
Installing window AC in metal frame sato HVAC 10 08-08-2009 10:15 AM
Metal Front Door with screws that keep coming loose MicheleWilliams General DIY Discussions 7 12-27-2008 10:59 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
Attaching Roof to side of home joe3534 Roofing/Siding 1 04-29-2007 10:54 PM
