Loose Outdoor Step - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 01:49 PM   #1
Rewards Points: 31
Loose Outdoor Step
I have a set of steps that I built into the side of a bank. Each step was anchored with rebar that was driven into the back of the step and then in turn driven into the bank.
It became necessary to dig down to the rebar at the top of the steps due to a drainage problem. By doing this, I now have the rebar completely loose. This rebar is necessary to anchor the top step so need some direction how to solve this dilemma.
I plan to fill the cavity that has been dug with small rocks that will facilitate drainage into the hole instead of cascading down the steps. In the area where the rebar is I have dug holes and plan to add cement to the holes and build a form that will enclose the rebar in cement too.
My question, is there a way to drive a rebar perpendicular to the rebar coming out of the steps, attach it to the step rebar with some kind of connector? Then I would encase the entire joint in cement.
Do you think that would hold the step in place? Or, do you have another suggestion?
Here are some pictures http://www.flickr.com/photos/52533242@N08/?saved=1
Thanks,
Randal
sharingsunshine is offline   Reply With Quote
Old 07-27-2010, 03:24 PM   #2
Rewards Points: 5,336
Why not bend the rebar into a very tight "U", drop it over the top and tie it with wire or weld the 2 together?
Ron
Old 07-27-2010, 05:04 PM   #3
Rewards Points: 31
Thanks for that suggestion. I am not sure how I would bend the rebar and I don't know how to weld nor do I know anyone locally that does.
Can it be bent without being heated up?
Old 07-27-2010, 06:26 PM   #4
Heat makes it easier.
Ron
Old 07-28-2010, 06:59 AM   #5
Rewards Points: 31
Thanks for your help and suggestions.
Abloy Front Door Lock is loose - how to open to tighten Wayne_in_Canada Windows and Doors 4 09-23-2012 07:48 PM
Damper motor has loose wires how to access? g8rben HVAC 1 07-01-2009 06:47 PM
Handles for metal framed patio door coming loose abefroman General DIY Discussions 5 06-19-2009 09:54 PM
Gets Loose!!!!!! J. V. Plumbing 7 05-11-2009 03:08 PM
Loose / Bent Faucet yasman Plumbing 1 03-30-2009 08:50 PM
