Loose Fill Insulation In Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 10:53 AM   #1
Loose Fill Insulation in walls
Can I use loose fill insulation for a 2x3 studded wall?
Here's my plan to insulate cinderblock walls in a partially underground basement.
1. Attach unfaced 1/2" polystyrene sheating to the cinderblock and seal the joints.
2. Frame a wall with 2x3s directly against the sheating.
3. Attache Drywall to the frame, leaving a gap at the top.
4. Blow cellulose loose fill insulation into wall cavity.
5. Fill the gap part of the cavity with standard fiberglass insulation.
6. Drywall the gap.
HooKooDooKu is offline   Reply With Quote
Old 01-18-2010, 06:05 PM   #2
An old Tradesmen
Rewards Points: 8,154
Moved to Building and Construction forum.
Old 01-18-2010, 08:03 PM   #3
Registered User
Rewards Points: 526
Sounds good! Use p.t. bottom plate, caulk all surface connections, hold drywall up ” above floor, use a sill sealer under plate for a thermal/capillary break, add foam board on top of concrete stem wall- caulking first, depends on location for v.b., v.r. or not, and meet required basement R-value in walls:
http://www.buildingscience.com/docum...gs?full_view=1
http://www.buildingscience.com/docum...ecommendations
http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html
R-1.11 for 8” block: http://www.coloradoenergy.org/procor...f/r-values.htm
Be safe, Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Basement walls and insulation hodak Carpentry 3 11-24-2009 12:58 AM
2x6 insulation in 2x4 walls.. Bad idea or just fine? slowjo Building & Construction 14 06-10-2009 09:00 AM
Rigid Insulation on the interior walls during remodel KHM Building & Construction 2 04-29-2009 09:08 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
