Loose Collar Tie - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 02:32 PM   #1
Loose Collar Tie
Hi guys,
I'm in the process of laying flooring up in my attic for storage purposes and I noticed a loose collar tie at the very end of the attic. Upon closer inspection I noticed that one end of the collar tie has only 1 nail holding it to the rafter whereas all the other collar ties have 4. It looks like the collar tie has started to warp and it seems very loose, if I try to move it by hand there is quite a bit of play. All the other collar ties seem rock solid if I try to move them by hand. What should I do here? can I just put in a few more nails on the one end and it should be ok or should I replace it completely? The collar ties are 2x4 and the roof rafters are 2x6.
here are some pics
The collar tie in question, only one nail
warping
all the other are attached with 4 nails
Any help would be greatly appreciated!
nofx1981 is offline   Reply With Quote
Old 02-03-2010, 02:41 PM   #2
jlhaslip's Avatar
Rewards Points: 2,872
pound in a few more spikes and it will be good
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-03-2010, 03:40 PM   #3
That's what I was hoping to hear. And if it still feels wobbly i think I'll nail in another 2x4 just above the existing one...
Old 02-03-2010, 07:29 PM   #4
That tie is so close to the gable, that is has little importance! The gable would prevent any collapse of the rafters!
Just put another 3 nails in, and call it a day! No need for another tie!
Old 02-03-2010, 10:12 PM   #5
I guess that's true Wildie, I didn't think of that! Thanks for the replies!
I'm glad this isn't as big a deal as I thought it might be.
Old 02-05-2010, 11:02 AM   #6
looks like youve got collar ties on every rafter. So your in good shape. A lot of places/codes only require one on every other
noahwebseo is offline   Reply With Quote
Old 02-09-2010, 08:40 PM   #7
yup, collar tie on every rafter
Abloy Front Door Lock is loose - how to open to tighten Wayne_in_Canada Windows and Doors 4 09-23-2012 07:48 PM
Damper motor has loose wires how to access? g8rben HVAC 1 07-01-2009 06:47 PM
Gets Loose!!!!!! J. V. Plumbing 7 05-11-2009 03:08 PM
Loose / Bent Faucet yasman Plumbing 1 03-30-2009 08:50 PM
Removing Collar ties Mike2004 Building & Construction 6 12-16-2006 01:48 PM
