Looking For Suppliers For Low E Foam Board And Fiberglass Batts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 11:34 AM   #1
Rewards Points: 234
Looking for suppliers for Low E foam board and fiberglass batts
Looking to purchase about 20K sf of insulation and just wanting to do some price shopping. Looking for references for the low E foam board to be applied between the sheeting and frame of a structure as well as plastic backed batts for final interior insulation. Not yet sure if this stuff will be more economical to try and buy local or buy outside of my state and have shipped.
viper is offline   Reply With Quote
Old 06-02-2011, 02:02 AM   #2
Rewards Points: 1,092
Are you set on the plastic-backed batts (FG?) ? What is low e foam? Blue board? (XPS)? EPS? Just curious what the application is, too.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 04:46 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
Diference between Fiberglass and Hard Foam shumakerscott Roofing/Siding 3 09-06-2008 12:16 PM
