10-31-2011, 06:16 PM
#1
Green Building Enthusiast
Looking for suggestions on installing concrete below tile on elevated floor
Originally, we were planning on pouring an approximately 2" thick concrete slab on the main floor of our house to run our in-floor heat through as well as gain some passive solar heat. We were going to finish the floor by polishing it to a nice shine. The quotes have came back and it's becoming very pricy to have the polishing completed.
Having said that, we're still looking at putting down about 1-3/4" of a concrete type product as a sub-floor, then installing tiles on top for the finished product.
Does anyone have any suggestions of what type of concrete I could pour that will not cause the tiles to pop, be relatively easy to work with (moderately self-levelling) and isn't over priced. My initial thoughts are to just order regular portland cement concrete with 3/8" aggregate, but request a higher slump.
Thank you
10-31-2011, 07:08 PM
#2
Thank you
You need a light, weight gypsum based mix. It's self leveling. You need to find out the particulars of the subtrate needed.
What were you putting this concrete over?
Ron
B. Franklin 1759
10-31-2011, 07:21 PM
#3
Tileguy
What type of in-floor heat are you planning to use?
10-31-2011, 08:04 PM
#4
Super Moderator
Just a few more details needed---
10-31-2011, 08:19 PM
#5
I am utilizing a solar thermal system with electric backup with flexible pipe embedded (I am not the in-floor heat provider). I am likely going to install it over 3/4" t&g plywood, but this is not set in stone.
As for the light-weight gypsum mix, how well does that store heat from passive solar gains? It would seem to me that the gypsum mix wouldn't store and release heat as well as a standard weight concrete.
10-31-2011, 08:31 PM
#6
Super Moderator
Sounds like you need mass----I think concrete is the best solution---However--
Concretemasonry--or itsreallyconcrete--(members) have a great depth of knowledge on that --so I'll see if either one check in before I put in my two cents---Mike---
10-31-2011, 09:36 PM
#7
Tileguy
Tile over lightweight (Gypcrete) has its issues. The lightweight must be addressed before tile can be applied to it.
10-31-2011, 10:47 PM
#8
It might be helpful if the OP mentioned the structural supportthis was going on.
The "elevated" aspect has piqued my interest.
Ron
B. Franklin 1759
10-31-2011, 11:24 PM
#9
Ron6519 - I'll be designing my floor joist system to support the additional weight of the concrete, I don't have a concern there.
I'm looking for some suggestions on a product that I can pour pretty much level the first time, will allow a good bond to tile and will provide sufficient mass for passive solar heating purposes.
Does anyone have an opinion on how a small aggregate concrete mix with a slightly higher slump would work in this application?
10-31-2011, 11:33 PM
#10
Tileguy
You could use Self Levelling Compound (SLC) and add some pea gravel to it for bulk.
The SLC would serve as your thermo-mass and your tile-backer at the same time.
The Following User Says Thank You to Bud Cline For This Useful Post:
11-01-2011, 12:56 AM
#11
liscenced electrician
im not an expert on the matter, more curious than anything. but isnt 1 3/4 a little thin for concrete? Especially with flexible pipes running in the middle?
11-01-2011, 03:45 AM
#12
11-01-2011, 08:26 AM
#13
normally thermal mass depends on mass,,, suspect passive solar would benefit from 1 1/2" just as well as 4" BUT no date to confirm,,, you are correct in getting small coarse aggregate for thin floors especially when encasing infloor heat,,, depending on your location ( e b/f or not )/amt of work/avail power, polished conc should compare quite well against tile but its not my house - self levelers are a pita unless 1 has some experience placing them
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-01-2011, 09:18 AM
#14
Concrete & Masonry
Thank you
We usually do this at least once a year, oftentimes in zero-entry accessible homes. It allows for curbless showers.
We've never had a problem getting the standard pea stone (3/8") mix to work out for loading the floor joists, as it's only about 22#'s per sq. foot for standard weight concrete. Lightweight agg. would only get you down to about 18#'s per sq. ft. with the agg. we have available here. Not worth it for the extra money in most cases. Obviously, the additional weight of the concrete has to be figured into the equation when the floor system is engineered.
As for the mix, we typically use a 5.5 bag (same as 3500 pis mix, but with straight cement) with a double dose of fibers, as well as a mid-range water reducer to bring the slump up to about 6" to ease installation.
Just be forewarned though. This is far from self-leveling and requires quite a bit of labor and experience to get down flat enough for tile. If you try to bite off more than you can chew, you'll likely burn out or the concrete will set faster than you can finish it. You can always use a self-leveling compound over it if it get's away, but it's a waste IMO when putting a good finish on the concrete right away is far easier & cheaper. That being said, I'd likely hire it out to a pro if you don't think you have the experience.
11-01-2011, 12:51 PM
#15
now the thing is this that if you want to install new tiles in the floor and want to make is concrete then you should to use the varnish inside the tile this is my personal experience.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
