Looking For Some Advice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 10:20 PM   #1
looking for some advice
Hi Forum members,
I am looking for advice on roof framing with regards to size of rafters and ridge board.
I am building a storage shed that will be 12 X 16 with 8 ft. sidewalls. The pitch will be a 5/12 so do I need 2 X 4 or 2 X 6 rafters? Should I use a 1 X or a 2 X for the ridge board?
Thanks for any help you can offer.
Larry
alke46 is offline   Reply With Quote
Old 11-19-2009, 07:29 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
What is the length of the ridge board? 12' or 16'? What is the dead load of the roof decking, materials? You don't have your location posted, so no-one knows if snow load has to be calculated. Will there be rafter ties, or ceiling joists to tie the rafters together? You need to answer all of these questions.
Old 11-19-2009, 10:17 PM   #3
Originally Posted by Maintenance 6 View Post
What is the length of the ridge board? 12' or 16'? 16'
What is the dead load of the roof decking, materials? I wish I had an answer for this part. I have no idea what the dead load is or how to figure it. Sorry
You don't have your location posted, so no-one knows if snow load has to be calculated. Omaha, Ne. As a worst case scenario, we might get 1 or 2 snows in the range of 7-12", but mostly our snow is in the lighter category and wind driven. I would not think snow on the roof would be a huge issue.
Will there be rafter ties, or ceiling joists to tie the rafters together? Ceiling joists.
You need to answer all of these questions. I hope this helps and thank you for your answers
I look forward to all comments.
Old 11-20-2009, 12:28 AM   #4
Registered User
Rewards Points: 4,924
You have to use 2x6 rafters: http://www.cityofomaha.org/planning/...SpanTables.pdf
You have to show the City where it is to be located but may not need a permit: http://www.cityofomaha.org/planning/...tePlanShed.pdf
2x8 ridge, build for snow. (One size larger than rafters).
Be safe, Gary
Old 11-20-2009, 09:43 PM   #5
Thanks for your help. I was leaning towards the 2X6 rafters just because I thought they would provide a stronger roof. Wasn't sure though as to the width of the ridge board, so thanks for your input.
Old 11-21-2009, 08:38 AM   #6
ccarlisle's Avatar
Why don't you just post this on the roofing forum? That's what it's for!
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-21-2009, 11:06 AM   #7
Maybe because I thought it was a general framing question.
Old 11-21-2009, 10:16 PM   #8
ya those roofers don't know squat about framing.
the carpenter is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
I have to replace top seal plate any advice sharppick Roofing/Siding 3 04-24-2009 09:53 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 02:55 PM
