Looking For Solution To Seal Pipe Surrounding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 09:46 PM   #1
Question
looking for solution to seal pipe surrounding
Bad leak around the septic pipe penetrating basement foundation wall. I chiseled off surface cement. Under the thin layer strong cement, I found about half inch loose cement, loose like cookie; inside there is another half inch dirty hemp rope, then empty gap around pipe going 12-inch deep. I guess the other end is also the same. No wonder it leaks so badly in raining day. refer to pictures for before and after.
The outside of the house around the pipe location is a 7-foot wide, 4-foot tall stone-concrete porch. The pipe is 4 feet underground, 8 feet below porch. No one want to tire down the porch to fix the leak from the outside.
I can only do water-proofing from the inside of the basement. I am looking for solutions to seal the gap between the pipe and foundation wall. As you can see, the gap is no symmetric.
here is what I am trying to do:
Inject foam sealant first; then half inch polyurethane, then cover with half inch hydraulic cement. How’s that sound to you?
looking for solution to seal pipe surrounding-after.jpg   looking for solution to seal pipe surrounding-before.jpg   looking for solution to seal pipe surrounding-outside.jpg
dongdong1 is offline   Reply With Quote
Well pipe access shutdown HomerRepair Plumbing 6 03-08-2011 10:22 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
running black gas pipe lukeg Plumbing 6 10-25-2009 12:16 AM
