Looking For A Product To Keep Yard/grass/leaves From Entering Thru The Garage Door? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 08:18 PM   #1
Rewards Points: 212
Looking for a product to keep yard/grass/leaves from entering thru the garage door?
I always seem to have grass clippings entering thru a gap at the bottom of the garage door. I've installed a new rubber trim for the bottom however when they built this house and poured the concrete for the garage, they didn't do a very good job because the concrete has a 2"x6" cut-out and it's not very clean and allows for many gaps.
Is there some products you can recommend for the concrete floor that I can install to keep out grass and leaves?
imola ghost is offline   Reply With Quote
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 10:15 PM
Garage Door Insulation PaliBob Building & Construction 4 03-27-2009 03:05 PM
stuck garage door stuckdoor General DIY Discussions 7 08-30-2008 03:30 PM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 11:36 AM
