Looking For Input On Using Incense Cedar For Decking... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 12:54 PM   #1
Looking for input on using Incense Cedar for decking...
Anyone have experience with this type of cedar? Good, bad, otherwise? It's a white cedar from what I can find out, just curious on life span for decking as I've never heard of this type before.
OKDrew63 is offline   Reply With Quote
Old 08-26-2012, 01:43 PM   #2
Too Short? Cut it Again!
Incense cedar might be worth considering for some of the deck but it is fairly soft and is perhaps not the best of choices for the actual decking. The heartwood is nice looking and takes finishes really well. When working on the West Coast I used it quite a bit, for awhile, to make landscape lighting fixtures and things like that.
http://www.decks.com/deckmaterials/Types_of_Cedar
Old 08-26-2012, 03:23 PM   #3
So something that won't get a lot of traffic or wear would be a good use for it?
Thanks for the info.
Old 08-26-2012, 03:41 PM   #4
Rewards Points: 14,014
http://cdlumber.com/species/incense.html
Old 08-26-2012, 04:56 PM   #5
Something like Port Orford Cedar would be a better decking choice in my opinion but it depends on how much wear the deck will get I guess. And budget. I certainly went through thousands of board feet of redwood for decks and furniture at a hardness around 420. Here are some Jenka hardness ratings for comparison.
350 - Western Red Cedar
470 - Incense Cedar
630 - Port Orford Cedar
420 - Redwood
380 - Northern/Eastern White Pine
420 - Idaho White Pine
690 - Southern Minor Pine
870 - Southern Major Pine
660 - Douglas Fir
From there you start getting into synthetics or hardwoods for exterior use like teak with a hardness rating of 3500 or so.
Composite and engineered strand bamboo actually makes beautiful low maintenance decking and is way up on the hardness scale up around 3,000! It is not too terribly pricey either and some of it comes with incredible warranties on both materials and finish. The nicely engineered material has hidden fastening systems too. Like anything look for quality and you will not find it in box stores. Some of the non-slip profiles are really nice for wet areas.
Last edited by user1007; 08-26-2012 at 05:05 PM. Reason: Added Photo of Engineered Bamboo Decking
The Following User Says Thank You to user1007 For This Useful Post:
kwikfishron (08-26-2012)
Old 08-26-2012, 06:40 PM   #6
Budget is definitely a factor. This will be a 16x16 deck with a hot tub on it, I was figuring on 2x decking, whatever type of cedar I go with. I have not seen what bamboo would look like, will need to google it. I will have the need for 5/4x6 or 1x6 as well as maybe some 2x4 boards, the lumber would need to come in these dimensions as well.
Not too terribly pricey can have a lot of different definitions.
Old 08-26-2012, 08:12 PM   #7
The bamboo doesn't look too bad, at least the BamDeck stuff. A quick search and I found it around 3.24/1x6x8' board (3/4"x5/12").
Any idea how hot the surface would get in full sun? Air temp around 95-100. Curious if it would be painful when barefooted.
Good suggestion. I think it would look fine with cedar around it.
Need advice on putting cedar T&G planks on ceiling in bathroom pazure Remodeling 1 03-09-2012 01:07 PM
New basebords and trim are white but all window frames are stained cedar? mibson Interior Decorating 0 01-22-2011 01:27 PM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 07:51 PM
cedar deck looks like crap silky Painting 16 05-02-2009 10:42 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
