Looking For Exterior Finishing Ideas For 1920's Craftsman Stucco Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 10:16 AM   #1
Question
Looking for exterior finishing ideas for 1920's craftsman stucco home
My wife and I have recently purchased a Craftsman bungalow, originally built in 1922. The exterior is painted stucco. The stucco is patterned and unusual. We are wanting to add on a couple of very small additions to the house and want it to look period. However, local guys advise us they cannot mimic the stucco so that it would not look like an addition.
Does anyone have any ideas? One of the bidding contractors suggested we use beadboard exterior and paint it the color of the stucco. The rationale is that beadboard was used with craftsman stucco homes in the 20's. But, I have never see this done and can't picture it.
Looking for ideas or opinions.
Looking for exterior finishing ideas for 1920's craftsman stucco home-img_1439.jpg   Looking for exterior finishing ideas for 1920's craftsman stucco home-img_1440.jpg   Looking for exterior finishing ideas for 1920's craftsman stucco home-img_1441.jpg
Keeney is offline   Reply With Quote
Old 02-04-2013, 11:30 PM   #2
Do you have a picture of the exterior? Most craftsman homes were built between 1910-1925. The exterior finishes that I have studied and noted are stucco, wood siding and wood shingles and some brick work along the facade/front of home around covered porches. I would recommend looking at William Morris and mission eras for inspiration as well as other craftsman homes online galleries and see what you are liking.
AppealingSpaces is offline   Reply With Quote
Old 02-05-2013, 02:00 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
I have worked on and designed for a number of California Bungalow homes that have had a vertical bead board around the skirt but not as one of the main field components.
they are here in So. Cal in the Old Town Historic District in the city of Orange.
I can't remember any Craftsman homes with the same though.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Keeney (02-05-2013)
Old 02-05-2013, 02:03 AM   #4
Rewards Points: 13,250
http://www.bing.com/images/search?q=...alow&FORM=IGRE
Keeney (02-05-2013)
Old 02-05-2013, 09:39 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
consider using the vinyl cpvc T&G bead board. you can get the beaded look or the v groove look,3" sizes or 5 1/4" sizes. Horizontal skirt board along the bottom of the wall with a drip cap and then t&g down to the drip cap...
the addition will need periodically spaced horizontal in wall blocking to accommodate the t&g siding
hand drive is offline   Reply With Quote
Old 02-05-2013, 09:46 AM   #6
You can buy it like this that's about .050 thick or even solid. Not cheap but no maintance.
http://www.bing.com/images/search?q=...electedIndex=1
Keeney (02-05-2013)
Old 02-05-2013, 12:04 PM   #7
Rewards Points: 526
I would steer clear of vinyl. There are already too many craftsman homes that have been spoiled by vinyl and aluminum. THe actual style of the siding should be secondary to the Arts and Crafts ethos of simple design; hand crafted; natural material -- if you follow these directives, it will look good. There are so many good books out there that might give you some ideas. http://www.amazon.com/Bungalow-Detai.../dp/1586853066 The author is quite hilarious too and it is may be available at your local library.
Windows is offline   Reply With Quote
The Following 2 Users Say Thank You to Windows For This Useful Post:
AndyGump (02-05-2013), kwikfishron (02-05-2013)
Old 02-05-2013, 02:45 PM   #8
pictures added above. Thanks
Old 02-05-2013, 04:41 PM   #9
You need some stucco guys who actually know what they are doing.
Not trying to a smart-a**, but thats a simple "pull" pattern, with a light knockdown.
Very easy to match.
Usually pulled with a flat square sponge, let it set for awhile, then lightly knocked down with a SS trowel.
BLKZ06 is offline   Reply With Quote
The Following 3 Users Say Thank You to BLKZ06 For This Useful Post:
Keeney (02-05-2013), kwikfishron (02-05-2013), retro (02-05-2013)
Old 02-05-2013, 10:36 PM   #10
Thanks. I have been listening to contractors. It sounds like I need to do some calling around on my own.
Old 02-06-2013, 09:19 AM   #11
Rewards Points: 150
Agreed they just don't want to do it. It can be done with stucco. At worst they have textured cement board
kaschmid3 is offline   Reply With Quote
Tags
exterior design , home additions , stucco addition
NEED HELP WITH IDEAS for remodeling a entire home 2100sq ft 2 stories *Many pictures* BleachCola Remodeling 26 08-23-2008 07:15 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 08:07 PM
Cool Ideas for a Urban Home Elizabeth Interior Decorating 1 06-18-2008 01:24 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
