Looking To Do Large Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2008, 08:04 PM   #1
Looking to do large shed
I am looking to do a 16'x20' shed or something close to that. I see alot of 12x24' in my area for sale and was wondering if it was because of no wasted material. I will mainly use the shed for the lawn mower, tools, ect. I was going to do a 8' wall so I could add a few shelves as well. Ideas are welcome. I will not be pouring a foundation. I am going to put the building up on blocks and installing siding to match the house.
Mack V is offline   Reply With Quote
Old 02-13-2008, 09:41 PM   #2
Extreme DIY'r Adk's, NY
Rewards Points: 272
12x24 would fit a vehicle. 20' deep would not fit most vehicles. This may be one reason. Any increment of 4' or even 2' works for material. In general, the squarer the building the more efficient the material usage tends to be, but not always. Build what you need.
crecore is offline   Reply With Quote
Old 02-14-2008, 01:14 PM   #3
12' also is easier to transport. You can't put a 16' shed on a flatbed. That might be why you see 12' sheds for sale around you.
NateHanson is offline   Reply With Quote
Old 02-14-2008, 04:26 PM   #4
Thanks, keep them coming. Is there any problem w/ putting a 4000 lbs. car in one of these if I use 4x4 as the base and 2x6 on top of those spaced 2' apart. If so how far apart should the 4x4's be spaced?
Michael
Old 02-14-2008, 09:05 PM   #5
Hey Mack, I built a 12x16 shed last summer for the exact same reason, tools and lawn equipment. I used 2x6 floor joists layed on 6x6 p.t.. I used 3/4 tg plywood, 8' walls and it was plenty of room for everything. I too matched the siding, roofing shingles, dormers and shutters and everything together ran about $3500. If you are going to use it for a car, I would definitely use 6x6, with 2x8 floor joists 12oc and maybe even double the 3/4 plywood. That's a lot of weight to put on a wood shed. I spaced my 6x6 about three feet apart and went lengthwise but if you use it for a car I would probably use 4-6x6's no more than three feet apart with a 1 foot overhang. Let me know if you have any questions. I can send you pics if you want.
vtsweener is offline   Reply With Quote
Old 02-15-2008, 12:04 AM   #6
Thanks for the info. I will might just need a pic. for some ideas. I will pm you.
Old 02-15-2008, 12:11 PM   #7
Rewards Points: 150
I did a 10' x 15' shed since the house we bought only had a carport. No car storage, so I used some more basic contruction. Piers for foundation, 4x6's on piers, 2x6 floor joist, 3/4 T/G floor, 8 foot walls = room for lots-o-stuff. Below are pics from a Saturday morning to the following Sunday evening. One more day to finish the siding and doors and build shelving for inside.......
Looking to do large shed-shed-saturday-morning-small-.jpg   Looking to do large shed-shed-sunday-afternoon-small-.jpg   Looking to do large shed-shed-sunday-night-small-.jpg
steve1234 is offline   Reply With Quote
Old 02-15-2008, 03:58 PM   #8
Nice pics.
Old 02-15-2008, 08:30 PM   #9
robertcdf's Avatar
Another option is to frame the floor with 2 runs to support the car. In other words mesure the distance between the tires and reinforce that area. This will save you a little bit on your floor. I would recomend 6x6's on the bottom and then 6x6's where the tires will be. Then you can use cheap 2x6's for floor joists everywhere else.
robertcdf is offline   Reply With Quote
Old 02-15-2008, 11:02 PM   #10
Sweet that rocks. I will do this if I do it larger for the car.
Old 02-16-2008, 12:37 AM   #11
Rewards Points: 6,652
That is not a Shed, that is a Garage. Matter of fact, it is larger then my Shed Garage, which is 12x16.
Old 02-17-2008, 07:55 AM   #12
I might end up doing a size like that but everyone keeps telling me to double the size I think I might need. I guess it's easier on there wallets.
Old 02-17-2008, 06:33 PM   #13
I would pour concrete if your looking for car storage. why push the limit ? savings vs. possible damage = dumb, pour slab then build away.
big daddy-o is offline   Reply With Quote
Old 02-17-2008, 07:25 PM   #14
Well, in my area they would consider adding to the value of the house (taxes) if it is a poured foundation. I might not do the storage for the car as I am still undecided which way to go. This is why I chose to do it on blocks.
sealing a shed Alex R Building & Construction 1 01-04-2008 10:57 PM
Shed: One light, one plug Crackers Electrical 2 08-31-2007 05:09 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
How to roof a small shed???? Sellncars Roofing/Siding 2 09-22-2006 11:21 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
