Old 10-25-2010, 04:27 PM   #1
longer frame screws in interior door?
I am putting new solid wood doors in our house and they come with brass hinges that have a whole 3 1" screw per side of the hinge... should I get longer screws for one of each of the three hinges to screw into the stud frame? I know you do this on exterior doors to make them more stable / sturdy, but is it good to do inside also? thanks!
BlueBSH is offline   Reply With Quote
Old 10-25-2010, 05:18 PM   #2
the Musigician
DangerMouse's Avatar
Couldn't Hoit! Woowoowoowoowoo
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 10-25-2010, 05:21 PM   #3
Graphics Specialist
kredman's Avatar
I would!
kredman is offline   Reply With Quote
Old 10-25-2010, 05:23 PM   #4
jlhaslip's Avatar
Yes, but make sure you shim behind each hinge or the longer screws will pull the frame out of plumb.
By the way, adding long screws will only work well if you hit the framing.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (10-25-2010)
Old 11-01-2010, 03:15 PM   #5
anyone know what size screw a standard hige takes? I'm having problems matching the head size....
Old 11-01-2010, 04:00 PM   #6
jlhaslip's Avatar
try a number 8.
Old 11-01-2010, 04:02 PM   #7
Originally Posted by jlhaslip View Post
try a number 8.
thanks, was using #10 because it seemed like it was the same size... but found out fast it wasnt....
Stripped out door hinge screws krankykitty Carpentry 23 01-16-2012 10:23 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
underlayment for stick on tiles or vinyl novice40 Flooring 7 09-03-2008 05:49 PM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 02:31 PM
Installing an Anderson sash, without frame NateHanson Building & Construction 3 10-03-2007 06:28 PM
