Long Verticle Metal Siding Application - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 10:03 AM   #1
Solutions (handyman)
Rewards Points: 364
Long verticle metal siding application
I have an opportunity to bid on a job that is to re-side a shop. My concern is how best to apply long lengths of verticle siding (16' & 20') sections without the panels bending. Advice is appreciated.
Mark Harvey is offline   Reply With Quote
Old 11-20-2012, 10:08 AM   #2
Rewards Points: 13,472
Going to have to let us in on exactly what this siding is.
If it's delivered on a flat bed truck, off loaded with a piggy back fork lift and there's two people installing it I'm not seeing what the issue is.
12' pieces of flimsy vinyl siding is installed all the time without bending it.
When I see the guys installing the siding on car ports there's just two guys and a couple of drill drivers.
Old 11-20-2012, 10:33 AM   #3
Rewards Points: 364
Siding
I believe the siding is to be 29 gauge metal. The building contractor has informed us that it would be delivered to the site, all we are to do is install the panels and trims. I "assume" (I know, I know) that it will be delivered by the siding supplier and unloaded with a fork lift. That part may not be a issue. It's the lifting of one panel that will be up to twenty feet in length and placing it. Is there a method such as sliding the panel against the wall while lifting, ... or use of some backing material to keep it ridgid until it is placed? Hope this is clearer.
Mark
Old 11-20-2012, 11:08 AM   #4
Do not try and lift it laying flat. Just grab it by the outside long edge and lift it.
Draging it over the lower pieces may scratch them.
Old 11-20-2012, 11:42 AM   #5
Rewards Points: 2,212
are you installing it horizontal or vertical? sound like vertical.
how wide are the sheets? 3'?
mae-ling is offline   Reply With Quote
Old 11-20-2012, 01:40 PM   #6
Rewards Points: 364
Verticle and 3' width. Average lenght is 20'.
Old 11-20-2012, 04:11 PM   #7
Place scaffold about 2'-32" away from the wall. Scaffold with wheels is nice.
2 men grab one side of the sheet about 6' from each end. I like to pre-drill my holes for the screws - easier and looks better.
They carry it to the scaffold and hand it up to a 3rd man on the scaffold. If needed the top edge can have a pair of vice grips (pad them) attached with a rope attached, the 3rd man can use this to lift it up. the scaffold will likely need a mid level also. the guy carrying the top edge can scurry up there. (or have 4 guys)
slap er in place, level each sheet as you go and you are golden. (assuming corners are level, if not compensate as needed to make it look good.) It is amazing how much you can stretch the top or bottom of the sheets.
Old 11-20-2012, 04:13 PM   #8
Can do it with 2 men just more climbing up and down.
cutting metal barn siding jaydevries Building & Construction 8 03-03-2012 01:04 AM
getting ready to paint exterior metal siding. tips? annie68164 Painting 8 01-19-2011 04:52 PM
Window Flashing with Metal Siding vtboy51 Building & Construction 5 02-15-2010 05:00 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
