#1 |
Long deck poles
I'm building an addition that will feature a narrow, two-level deck with a gabled roof extending over it and I'm trying to decide what to use for poles. One side of the deck will rest on ledgers attached to the house. The other end has to be supported by poles. The width of the deck will be about 7 feet. I assume the best strategy would be to run the poles all the way from the footers up to the roof, but I'm not sure what I can use that will be long enough (It's 23feet to the peak of the roof). I could stack shorter poles at each level, but I like the idea of a single, solid support better. I've thought about using utility poles (telephone poles) and also raw tree trunks from eastern red cedars (got plenty of those on my property). But I want to know what other options there might be. I know you folks don't know about local code requirements etc. (yes it has to pass inspection), but if I get some good suggestions, I can ask about them at the permit office. I'm having trouble finding out what's out there, because all my searches for deck posts only list 4x4s and sometimes 6x6s, which are probably not adequate and are generally not 23 feet long.
#2 |
old guy contractor
Long deck poles
Go to your local lumberyard
You can buy/order 26' 2x8 and rip it down. Glue and screw the 2 pieces and end up with 23' 3x3's I'm not addressing aesthetics or stability.....
#3 |
Long deck poles
tcleve,
Thanks for that. I'm pretty sure that 3x3s would be too small, but the basic idea of laminating 2x8s is a good one. |
#4 |
old guy contractor
Long deck poles
You could also do a "Box Beam"
2 -4x4x12' (24') in the middle wrapped with 2x6 and 2x8 Scarf / 1/2 lap the joints of the two 4x4s |
| The Following User Says Thank You to tcleve4911 For This Useful Post: | Okie0030 (12-09-2011) |
#5 |
Long deck poles
Find a timber supplier, I can order up to 40x40 up to 40' length (and everything in between).
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 | |
Framing Contractor
Long deck polesQuote:
Joe Carola |
| The Following User Says Thank You to Joe Carola For This Useful Post: | woodworkbykirk (12-05-2011) |
#7 |
Long deck poles
could you have the footer stick up 3' (I'm thinking those concrete tube forms here) so you could just use 20' stuff?
#8 |
Long deck poles |
#9 |
Long deck poles |
#10 |
Long deck poles |
#11 |
Long deck poles
Any thoughts on just cutting and stripping some local cedars?
#12 |
Residential Designer
Long deck poles |
#13 |
Long deck poles |
#14 |
Long deck poles
Did it cost too much to have little detail included?
Andy. |
#15 | |
Framing Contractor
Joe Carola |
| Display Modes | |
| Deck Boards and Deck Size | Earnie | Building & Construction | 6 | 09-12-2011 09:38 PM |
| Ipe Deck Builder in Long Island NY | istadnyk | Off Topic | 1 | 09-19-2010 10:08 AM |
| Install a deck on top of a EPDM flat roof. | -Pjackso | Roofing/Siding | 16 | 08-02-2010 04:35 PM |
| Deck Staining Nightmare | steven994 | Painting | 2 | 06-17-2010 08:21 AM |
| Post detail for raised covered deck | jogr | Building & Construction | 3 | 05-16-2009 08:46 AM |
