Lolly Column - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2008, 10:54 AM   #1
Lolly Column
I have a home built in 1927. I am trying to finish the basement. The problem I am having is that the footing for the 3 lolly columns has a 3'x3' square around it and has a 4" rise, making the floor uneven and people trip over it. Is it ok to chip away at the concrete to reduce the footing size and then I can box out the column and have a evenly carpeted floor. Or should i put in a sub floor to level it out.
wyrld is offline   Reply With Quote
Old 11-07-2008, 12:10 PM   #2
Registered User
Termite's Avatar
I wouldn't advise modifying the footing that bears the lally column if you can avoid it. But, a couple inches won't hurt in most cases, assuming the pad is sufficiently deep. You might consider ordering a batch of lightweight flowable self-leveling concrete to raise the floor height. It would be cheaper than adding lumber and subfloor.
Lally column removal Joe F Building & Construction 7 07-03-2008 06:25 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 01:29 PM
Installing a structural fiberglass column Weekend Warrior DIY Building & Construction 9 11-19-2007 01:33 PM
lally column loosed from basement floor sonofthetonsured Building & Construction 8 06-28-2007 02:24 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 09:16 PM
