Log Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 10:04 AM   #1
log siding
Needing to replace the siding on my summer cabin this year. Vinyl would be the cheapest, but also considering log siding, to give it a rustic look. Don't know much about it though. I live in the middle of Nebraska, and only place I can get locally is Menards - cedar, spruce, or pine.
it looks like the pieces overlap each other, and no sort of tongue and groove set up, what is the likely hook of separating?
How much maintenance does it take per year?
Anyone have experience with this?
js2318 is offline   Reply With Quote
The Following User Says Thank You to js2318 For This Useful Post:
Mountain (01-30-2013)
Old 01-27-2013, 10:30 AM   #2
Any real wood product requires maintenance. Cedar is less susceptible to rot and insects, so safer.
Old 01-27-2013, 10:57 AM   #3
Rewards Points: 14,312
http://www.logsidingstore.com/
There's at least three companys that make insulated log looking vinyl siding.
Old 01-28-2013, 08:15 AM   #4
Rewards Points: 3,130
My wife and I have a log home (built it by ourselves). It's real logs, but the gable ends are matching log siding that's only 1-1/2 inches thick. It's been up just over three years, and there's no evidence of shrinking or separation. But ours came with the house kit and was kiln dried.
The only maintenance required is to restain every 5 years or so. We used Sikkens brand (quite expensive) but there are others. There are also additives you can get that will repel insects.
The last place you want to buy log siding is a big box store like Menards, unless you're filthy rich. There are literally dozens of log home companies in the U.S., many of which will sell you just the siding you need and deliver it. Our kit came from Daniel Boone Log Homes. They are headquartered in Nashville, TN. I'm sure there are others closer to you.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 01-29-2013, 11:59 PM   #5
Mountain's Avatar
I used to work at Homestead log homes in between Payette and Wieser Idaho. While I was there we came up with the idea of using the cut off log faces for siding and I walled an entire wall of the shop with it as a demo.
We ship lapped the edges of ours, it has been many years since I worked there but they may still be selling that. It was quite easy to install, not terribly expensive and with the shiplap edges went together quite nicely.
As for care, you will have to seal it and work on it every few years, that is just the nature natural wood.
I could get you the number and address of Homestead if you want to inquire about this siding.
Mountain is offline   Reply With Quote
The Following User Says Thank You to Mountain For This Useful Post:
oh'mike (01-30-2013)
Old 01-30-2013, 11:20 PM   #6
Mountain's Avatar
I found the website for New Homestead Log Homes, I did not see any of the log sideing on their products list, but here is a link to their site. Beings it is a side product it may not be listed on their site with the other products.
http://www.newhomesteadloghomes.com/
How to Nail New Siding Under Existing Siding Shuriko Building & Construction 25 05-21-2012 08:33 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
