Log Cabin Cathedral Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 04:10 PM   #1
I am looking for some ideas on how to insulate a ceiling in a log cabin. There is some insulation on the top side (R15) but I am thinking of adding insulation on the underside. Because the house is over 80 years old, I'd like to keep the appearance and also keep the weight on the ceiling down. I am thinking of having spray foam insulation installed and then installing ceder boards on top of it. I would probably have to install 2X6 ceder boards beside the balsam rafters to get a straight surface to attach the cedar boards to .
Anyone got any other ideas?
DCJH is offline   Reply With Quote
Old 01-12-2010, 06:58 PM   #2
jlhaslip's Avatar
Rewards Points: 980
You might be better off adding a 'cold roof' on top of the existing.
That would save your 'heritage' design of this building.
horizontal strapping, then add a new 'rafter system' above the strapping, insulate from the top leaving an air space, sheet, shingles, fascia, ridge vent, done. vent the fascia, of course.
jlhaslip is offline   Reply With Quote
Old 01-13-2010, 12:48 PM   #3
external roof
Thanks for the suggestion, but I have already installed a upper roof with special 2" (R15) fibreboard insulation. (Most people are not familiar with this stuff. It's like a hard fibreglass-type of 4X8 sheet..usually used in flat roof construction under tar.) On top of the roof is a Tough-Lok steel roof (50 yr warantee) that costs an arm and a leg but looks like cedar shake.
Condensation on cathedral ceiling barbaraizac Roofing/Siding 46 09-26-2009 11:48 PM
cathedral ceiling in my cabin fred klose Building & Construction 22 09-22-2009 07:32 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 11:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
